clutch problems ( please help )
Old May 3, 2015 | 09:03 PM
slotterjordan's Avatar
slotterjordan
Ok, so I've already replaced the master, slave, flywheel,pressure plate, and the disc. Everything has been fine for a good month. And now my clutch is loose at the top and when you mash the gas and rip acouple gears. Clutch drops to the floor and there is a little bit of pressure. I'm able to pump it back up . But when you push the clutch in and out a couple times it drops to the floor again. Now there is no pressure and won't pump up again. Fluid is dirty. I've flushed that thing out twice a month ago when I redid my clutch ( because my master took a **** )
So any ideas? This is really frustrating
Old May 4, 2015 | 12:57 AM
JSolo's Avatar
JSolo
Just say no!!!!!
My guess is air in the line or failed master or slave. Were these replaced with new parts?
Fluid should not be dirty after a month. Suggests something has failed and caused debris in the system.
Old May 4, 2015 | 09:41 AM
slotterjordan
Everything but the hose was replaced a month ago.
Old May 4, 2015 | 12:44 PM
JSolo's Avatar
JSolo
Just say no!!!!!
I'd take it back to whoever did the work for you. This repair must be covered under some type of warranty.
Old May 4, 2015 | 02:14 PM
slotterjordan
Me and my friends did it. We made sure everything was good. Not to mention we dropped the tranny twice for master slave, then the next week later for the clutch slipping. And put new fluid in both twice
Old May 4, 2015 | 03:37 PM
canucklehead's Avatar
canucklehead
not sure if this is the problem, but the service manual states to replace the slave and master at the same time. and the slave should be replaced each time the gearbox is dropped. so if the slave gets replaced, so does the master. and then fluid re+re as well.
worst case scenario is you have to drop again and re+re both the slave and master, then the fluid again. but since you want to be 100% this time (and i don't blame you) i'd spend a bit more and get the aftermarket HD slave kit. this should rule out any future slave issues if you do the install properly.
Old May 4, 2015 | 04:13 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Debris in the fluid must be coming from someplace... Either the master or the slave. Even if brand new, possible one has failed. Maybe something wasn't aligned correctly and cause premature wear....
stevo4756
Oct 9, 2015 01:54 AM
butwhatuptho
Oct 4, 2015 07:51 PM
MrRiv
Sep 29, 2015 04:59 PM
k19g37x
Sep 29, 2015 02:46 PM
r0cketm0nkey
Sep 27, 2015 01:34 PM
