lightweight flywheel chatter. fix??!??
Old Apr 5, 2015 | 12:22 AM
slotterjordan's Avatar
slotterjordan
I just installed new clutch and light weight flywheel. Is there any way to fix or quiet the annoying chatter you get when ideling. But when you push clutch in,it goes away. Sounds like a truck ideling. Also at very low rpm, the exhaust rattles. From the chatter. This is a huge common problem with every G. Someone please have a solution.
Old Apr 5, 2015 | 12:42 AM
quakerroatmeal's Avatar
quakerroatmeal
You knew this from the get go yet you still went for a light weight fly wheel? I don't think there's anything you can do..but go back to a stock flywheel.
Old Apr 5, 2015 | 02:43 AM
slotterjordan
I didn't. I researched a little and founded out now
Old Apr 5, 2015 | 08:02 AM
telcoman's Avatar
telcoman
Amazing!
What is wrong with the stock clutch and flywheel?
I still had the stock clutch and flywheel on my 06 G35 when I traded it in at 171796 miles.
They last a long time if you know how to properly drive a stick shift.
Telcoman
Old Apr 5, 2015 | 09:41 AM
slotterjordan
Originally Posted by telcoman
Amazing!
Telcoman
I just bought my 08 g37s at 88k. And my clutch disc and flywheel were destroyed
Old Apr 5, 2015 | 02:49 PM
telcoman's Avatar
telcoman
What was the difference in price between the OEM clutch and flywheel and the one you installed?
Old Apr 6, 2015 | 01:47 AM
vqsmile's Avatar
vqsmile
I just installed new clutch and light weight flywheel. Is there any way to fix or quiet the annoying chatter you get when idling. But when you push clutch in,it goes away. Sounds like a truck idling. Also at very low rpm, the exhaust rattles. From the chatter. This is a huge common problem with every G. Someone please have a solution.
Undoubtedly, the lighter replacement flywheel is not a dual-mass type like the OEM. It does not absorb nearly as much (any) of the sharp impulse energy of the raucous V6 in front of it, so it is allowed to transmit on through into the transmission and rattle the gears on the main-shaft, which typically sounds like rolling a bunch of heavy bolts around inside a coffee can.
I get frustrated with how often and how casually I see recommendations made here for people to just replace their OEM flywheel with a lightweight one. All they typically mention is how ridiculously expensive the OEM one is and how much better value the other is, without also making it clear how they are opening themselves up to potentially sounding like a cement truck.
Sorry slotterjordan, nobody ever said getting an education was cheap.
Old Apr 6, 2015 | 06:11 AM
I have 2 G37s with manual transmissions. Both have has the clutch and flywheel replaced. Neither has been abused or driven by someone who doesn't know how to drive a manual transmission. Mine has a very robust aftermarket clutch and lightened steel flywheel and my wife's has OEM replacement parts. Both of them sound like a cement truck. They did before and still do after replacement. Mine is not louder or worse than hers. The difference is in the engagement and pedal effort, as well as the clamping force of the clutch.
delfinparis
Nov 16, 2015 02:26 PM
parkern
Oct 1, 2015 10:15 PM
Msherburneg37xs
Intake and Exhaust
Sep 30, 2015 06:39 PM
Chris_M
Sep 25, 2015 08:38 PM
