Bcm/ecu
Old May 15, 2015 | 01:49 PM
blkceaser's Avatar
blkceaser
Bcm/ecu
All of a sudden my car won't start anymore. It was starting a few days ago and i know the battery is good. Could this be a faulty BCM or ECU that's causing this. I know the windows, radio, A/C, navigation etc aren't working as well
Old May 15, 2015 | 02:00 PM
GW330's Avatar
GW330
How old is your battery?
Old May 15, 2015 | 03:18 PM
telcoman's Avatar
telcoman
How did you test it?
Test each cell with a battery hydrometer
If you still have the original battery, replace it
Telcoman
Old May 15, 2015 | 04:26 PM
blkceaser's Avatar
blkceaser
the battery is actually brand new
Old May 15, 2015 | 04:29 PM
blkceaser's Avatar
blkceaser
I replaced the engine, Transmission, IPDM, and Starter. It was cranking fine until about a day ago it stopped. I was doing a search and saw how some people were saying the BCM could cause the car not to start and I was just trying to figure out if that wa thr case here or if I need to re-sync the BCM with the key
Old May 17, 2015 | 12:31 PM
Tachyon's Avatar
Tachyon
Did you try starting it with the key in the keyholder by your left knee? If its the bcm you should still be able to start it that way
Old May 20, 2015 | 08:05 PM
blkceaser's Avatar
blkceaser
I'll try t next, also what could keep the radiator fan from not coming on and I have been searching high and low for the bcm and ecu for my car and can't seem to find one anywhere without paying my soul for it. Any info where I can find them
Old May 21, 2015 | 06:26 AM
08skyline's Avatar
08skyline
Check the ground connection on the battery make sure it does move at all.
Old May 21, 2015 | 02:05 PM
blkceaser's Avatar
blkceaser
Could it also be the radiator cooling fan control module.
Old May 22, 2015 | 10:03 AM
blkceaser's Avatar
blkceaser
well could it
Old May 26, 2015 | 09:55 PM
blkceaser's Avatar
blkceaser
Can anyone recommend a place that does ECU and BCM repair??
