Rough Idle Running Lean
Old May 11, 2015 | 02:55 AM
604gz's Avatar
604gz
So i had to put in a new motor, i swapped everything over from the old one i set up the the turbos and everything made sure all the hardware and line are run correctly. i start my car and it runs, it is not running smooth as it should and it is very lean 16 on idle goes down when i throttle i ran for codes and get bank 1 is lean also i think the down pipe on the passenger side might not be fully sealed
Old May 11, 2015 | 10:25 AM
G37Sam's Avatar
G37Sam
It could be a million things really, doubt it's an exhaust leak though.
Do you have a Fuel Pressure gauge? Check your vacuum lines as well. Maybe the new engine flows a lot better than the older one?
You're either seeing more air, or less fuel, or the MAF sensor is not sensing right. Happy Troubleshooting.
Old May 11, 2015 | 12:28 PM
604gz's Avatar
604gz
From what i have just read according to the gtm manual my car wich is a 2008 has a diffrent fuel pump assembly and the new engine wich is from a 2009 has a completly diffrent fuel pump assembly now i am wondering if that is the root of the problem
Old May 13, 2015 | 05:11 PM
ANMVQ's Avatar
ANMVQ
Are you trying to run the stock pump? :/
The after market pumps come with hardware and new fuel line
Old May 14, 2015 | 02:55 AM
604gz's Avatar
604gz
I got it all figured out such a rookie mistske i had spark plug wires 3-5 reversed it working perfectly now!
Old May 14, 2015 | 06:06 PM
G37Sam's Avatar
G37Sam
^ That still doesn't make sense but I'm glad you got it sorted out haha
vamarris
Dec 9, 2018 11:10 AM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
delfinparis
Nov 16, 2015 02:26 PM
bobtaz13
Oct 1, 2015 01:39 PM
dedmanchan
Sep 24, 2015 11:25 PM
