Changed plugs now my engine is knocking
Old May 10, 2015 | 12:15 AM
35Sport's Avatar
35Sport
So I changed my plugs tonight and I took it for a spirited drive and now my engine is knocking. Limped it home, checked the oil and it was near empty. It knocks over 2k rpm. No codes are thrown, I'm going to throw some oil in it tomorrow and see what happens. Pretty sure it's broken though :/
Old May 10, 2015 | 01:41 AM
waterpyro's Avatar
waterpyro
spark plugs not oil plug right?
Old May 10, 2015 | 01:43 AM
35Sport's Avatar
35Sport
Correct, I edited because it turns out I was near empty on oil. Must have spun a bearing
Not sure what to do from here... LS1 swap?
I have an 08 35S, maybe a vq37?
Old May 10, 2015 | 02:11 AM
HoldmyMouse's Avatar
HoldmyMouse
Wow... how you lose all that oil? No warning lights?
Old May 10, 2015 | 02:19 AM
35Sport's Avatar
35Sport
No light came on, now I have a damaged motor
Old May 10, 2015 | 03:40 AM
G37Sam's Avatar
G37Sam
Are there any signs of oil leaks in your engine bay?
Old May 10, 2015 | 10:12 AM
35Sport's Avatar
35Sport
No signs of leaks. Bone dry...
Old May 10, 2015 | 10:30 AM
telcoman's Avatar
telcoman
Originally Posted by 35Sport
So I changed my plugs tonight and I took it for a spirited drive and now my engine is knocking. :/
How come you didn't check your oil prior to replacing the plugs?
I find it amazing that some never check their oil.
Telcoman
Old May 10, 2015 | 01:32 PM
JSolo's Avatar
JSolo
Just say no!!!!!
So it's just coincidence that it started knocking when you changed the plugs? That is, plugs really have nothing to do with the rod knock...
What was the condition of the old plugs? Wet, dry, color?
Old May 10, 2015 | 03:15 PM
35Sport's Avatar
35Sport
Yeah the coincidence was that I decided to run the car hard after the plug change. Hit redline a few times, made a weird noise and lost power on the last run. Immediate knock and stalling ensued. NO OIL LIGHT
Condition of the plugs were dry and burnt looking.
Old May 10, 2015 | 03:32 PM
35Sport's Avatar
35Sport
Telcoman
How come I didn't do a lot of things...doesn't matter now.
Old May 10, 2015 | 03:51 PM
Sounds like it's toast
Maybe you can locate a lower mileage salvage motor, or maybe, just maybe, something occurred that can be fixed at minimal cost. Good luck & sorry to hear of your dilemma.
Old May 10, 2015 | 05:10 PM
35Sport's Avatar
35Sport
Looks like a stock lower mileage replacement is around 2 grand shipped. That's according to ebay anyways.
Also ran across this beast... http://www.ebay.com/itm/Nissan-Titan-VK56DE-Motor-and-370z-Manual-Transmission-/191573208840?hash=item2c9aa72f08&vxp=mtr
Old May 11, 2015 | 02:48 AM
telcoman's Avatar
telcoman
It matters to others reading posts on this site that if they haven't checked their oil on a regular basis perhaps they should start to do so before they end up like you with a ruined engine.
You should change the title of this thread to "Never checked my oil, car now knocks."
Changing the plugs has nothing to do with you ruining a perfectly good engine that now knocks.
Telcoman
Old May 11, 2015 | 11:48 AM
GAWD's Avatar
GAWD
Not questioning anyones mechanical ability but a loose spark plug can & will make a disturbing knocking/ticking/pinging sound that is similar to a death rattle. Did you happen to have any trouble with removing or installing any of the plugs, like cross threaded or anything? Good luck.
