Transmission lagging question
Old Apr 14, 2015 | 11:35 AM
ravie's Avatar
ravie
hey guys I have some questions about my 2012 g37x sedan I say lagging in the title but I will explain, a lot of times when I take off I feel like am driving a manual transmission vehicle the power does not come on instant or according to the amount am stepping on the gas even on the highway when I try to change lane I have to make sure the rpm is up before I try change lane my thinking is if I change the transmission fluid maybe it will help the car has 60k can someone help with ideas or anyone going threw this issue.
Old Apr 14, 2015 | 12:12 PM
ryanwhite74115's Avatar
ryanwhite74115
Have you reset the tranny software? Your tranny is adaptive, so it might be shifting like a grandma based on prior history of the prior driver.
Old Apr 14, 2015 | 12:21 PM
ravie's Avatar
ravie
How do you reset the transmission software
Old Apr 14, 2015 | 01:38 PM
Limmerbr's Avatar
Limmerbr
Easy way is to leave the negative battery terminal disconnected for like 5 minutes then reconnect.
Then your starting at zero.
Old Apr 14, 2015 | 03:24 PM
laced11's Avatar
laced11
Grounding kit may help. Made a difference on mine!
Old Apr 14, 2015 | 04:01 PM
twin_snails's Avatar
twin_snails
Also, take your car to the dealer and have them check to make sure you're running the latest TCM module firmware. There are some very extensive threads on the forum about this issue, as well as shift issues in general. Infiniti is updating the TCM software on a pretty regular basis. I've had mine updated at least 3 times.
Old Apr 16, 2015 | 01:21 AM
ravie's Avatar
ravie
Well guys thanks a lot, i think I fix my transmission lagging issue. Here is what I did disconnected the battery, clean the throttle body, I didn't even take it off I just open the flap and clean it as much as I could, also I replace the air filters that was a little dirty, after I clean the throttle body I turn the ignition to the on position with the car off and I press the gas peddle all the way down and release, then I went about half way after that I went out and drive the car and right a way I felt a difference, the throttle is more responsive the car is more fun to drive now than before. Now let me say this I don't know which one of those things i did help but it work for me you guys should try these thing and see if it will help those who are having lagging issue.
Old Apr 18, 2015 | 02:00 AM
mickeytl's Avatar
mickeytl
Don't think I have lagging issue but gonna perform a reset anyways.
j50ny
Jul 21, 2017 10:46 AM
redlinernyc
Feb 29, 2016 11:06 PM
kavcheung
Jan 22, 2016 02:40 PM
Falker11
Sep 9, 2015 08:53 PM
