Please diagnose this noise
Old Jan 28, 2017 | 10:53 AM
zonnie's Avatar
zonnie
2010 g37xs with 80k miles serviced regularly and premium gas always used.
Heard this ticking noise, very consistent in nature, noticed it at idle after parking car.
Videos are crappy sorry but its a distinct ticking noise. What can it be? You can hear it more in video ticking 2.
Old Jan 29, 2017 | 04:22 PM
zonnie's Avatar
zonnie
bump........
Old Jan 29, 2017 | 06:37 PM
qmantran's Avatar
qmantran
Sounds like a motor making normal noises to me
Old Jan 30, 2017 | 02:50 AM
crookncastle's Avatar
crookncastle
can not make out any abnormal engine noise in either videos
Old Jan 30, 2017 | 12:50 PM
tank99's Avatar
tank99
Seems similar to all VQ's injector solenoids. I remember my 99 Maxima having very loud ticking.
Old Jan 30, 2017 | 02:02 PM
staskz's Avatar
staskz
normal, but i guess you are a perfectionist haha
Old Jan 30, 2017 | 02:37 PM
jgronline's Avatar
jgronline
Sounds like the lifters to me. Do you have enough oil? What kind of oil filter are you using?
This might help:
https://www.z1motorsports.com/engine...sh-p-2476.html
Old Jan 30, 2017 | 10:29 PM
TinsleyC's Avatar
TinsleyC
I can hear the ticking pretty clearly. It's likely play in the valves, but I'm hardly a mechanic. Does it increase with RPM's?
Old Feb 4, 2017 | 12:23 AM
Awgd8's Avatar
Awgd8
I had that in my VQ. It is not constantly there, but sometimes it sounds like a lifter sticking. Since you are already at 80k miles, I would switch to Synthetic High Mileage Mobil 1. I used to like Penzoil Ultra and Platinum, but VQ tends to not like these Penzoil oil. My issue was both my VQ35HR and VQ37VHR were prone to Valve cover oil leaks. Oil does not leak a lot (just damp or weep) but If you look around the valve (camshaft cover) where it meets with the engine block, there is 99% chance you have that issue at that mileage.
The driver side is prone to that than the passenger side. The VQ35HR already has 85k miles and before my extended warranty ended, I asked them to fix it. Currently not a single oil dampness in that area. ( Using Mobile 1 HighMileage)
The VQ37VHR, had some small oil weep on the driver side as early as 8k miles! That time I was using Penzoil Ultra Synthetic. I cleaned oil residue with few spray of engine cleaner and switched to Mobile1. So far both engine are clean of oil leaks.
