Oil Change Intervals Question - Very Low Miles
I have done a good bit of research on this forum about oil. I read the whole oil sticky. I know that it can be more of a matter of opinion but I am leaning towards going with royal purple for my first oil change coming up. I drive the car fairly conservative and I think I read that redline was better for very aggressive drivers. Plus I haven't really anything bad about RP.
Information in my car: 2012 auto with 62.5k on it. I bought it over 4 months ago when it had 60k. So that is why I'm coming up on my first oil change. I have no idea what they previous owner used.
Here is my issue... I put very few miles on my car. As you can tell from my information above. It is my daily driver but I work 3.5 miles from home. Also when we go on trips we always take my wife's FX35. I do plan on doing some day mountain runs but its always going to be about 5 months before I hit 3K on my oil.
Is that an issue? I know it should be change every 3 months but I will be at around 1.5K on the oil. If I use RP do you think that will let me get away with changing it every 4-5 months at 2-3K on it?
Thank you!
Thank you!
Here is what each day looks for me.
Leave for work at 8:50am. Get to work at 9. Leave for home at 11:50 arrive home at noon. Leave back for work at 12:50 pm get back at work at 1. Most of the time Ill take another break at 4:30 get home at 4:40 go back to work at 5:15ish and get to work 5:25pm. Ill work until 7:30 or 8 and stop by a store or whatever. Im home by 8pm. Do it over again lol.
I know that sounds like a crazy schedule but I work at a college and teach there as well. So its long days but also flexible. I also know that looks like a good bit of driving but im literally in my car for for just over an hour and only less than 25 miles a day. Prob only 10 miles on a weekend because we take my wifes car most of the time.
tbssimp (04-11-2017)
Infiniti recommends every 3750 miles/3 months for more severe operating conditions or 7500 miles/6 months for less severe (whichever interval comes first). You'll want to do your own math and determine your own suitable interval depending on your driving conditions based on the listed parameters.
I know its easy to change myself but I work a lot and I don't have the time and more importantly the tools.
I use Mobil 1 5W-30 every 3,500 miles. My car is a daily driver, no need for super special oils. It's good enough and doesn't give me any reason to switch. The fact that you barely drive your car means you probably shouldn't worry about it either.
Is this true?
You won't find your answer on the forums. What I suggest is run X oil for X months and then send an oil sample out to blackstone labs for an oil analysis. They'll be able to tell you exactly what's going on and suggest a routine for you.
I personally use Motul 8100 every ~4k miles.
