IPL Engine comparison to normal g37
Old Feb 5, 2017 | 12:35 PM
One_Deadly_G37's Avatar
One_Deadly_G37
Post IPL Engine comparison to normal g37
Idk if this been asked before but what exactly is different in the IPL engine to the normal 3.7 beside the ECU.
Old Feb 5, 2017 | 07:29 PM
Ape Factory's Avatar
Ape Factory
The engines themselves are identical. It's the ECU and the dual exhaust that make the difference in hp.
Old Feb 5, 2017 | 11:36 PM
One_Deadly_G37
so i could just buy a IPL ECU and put it on my car and pretty much have IPL numbers or could tuners copy the IPL tune data and just overwrite the data
Old Feb 5, 2017 | 11:39 PM
Ape Factory
Swapping ECU's is not that easy unfortunately. You'd also need a true dual exhaust. Honestly, you're far better off having your existing car tuned after you install the mods you want via EcuTek.
I found that even with an intake and high flow cats, my air/fuel ratios were in no way optimal (very, very rich in fact) and a tune will not only prevent this but you'll gain quite a bit more hp than just running an IPL ECU.
