Losing coolant in 2012 G37 Sedan
Hi guys, so a couple weeks ago I asked about the coolant in my 2012 G37 Sedan with 51xxx miles on it, and the reservoir was completely empty at that moment. I filled it up to the max line on 12/16/2016. Now, as of today, 1/15/2018, the reservoir is about to be empty again. I saw the coolant at the bottom of my car where we place the floor jack to lift the front of the car up. The leak seems to come from the driver side. What do you guys think that cause the problem? I am scared to death that I have blow head gasket in my engine ==". Thank you.
Before I put my 2012 sedan away for the winter, I noticed the reservoir was low. There's coolant stains all over the lower radiator hose. Hoping it's just a clamp. Will mess with it in the spring. Same year so maybe there was a bad batch of clamps?
Hopefully it's not the case, but I had a similar issue with mine and it ended up being a bad water pump.
Let us know how it goes.
https://www.myg37.com/forums/g37-sed...ml#post4143573
Hi guys, so I just did the blow head gasket test with the Combustion Leak Detector at the radiator cap hole for 2 times. The 1st time was after the car had been running for 3 mins, and the liquid stayed blue. I then waited for another 2 mins and did the test again. The liquid still stayed blue, but it started to sucked in the coolant now because the car was warm enough, so I had to stop. I guess I am safe to say that I don't have the "blow head gasket" for now, but now I am scared that I have a bad water pump. If that is the case, then I guess I will have to suck it up and bring it to a mechanic to a complete tune up ==". My pocket is hurting right now
1st time:
2nd time:
1st time:
2nd time:
The coolant level after 5 mins total, and this coolant is GREEN. Anyway, I add the Nissan Blue in for both times =.=
As you can see, the coolant reservoir looked like it was empty, but it actually had a little bit left over from the 1st time which is a couple weeks ago LOL
TBau651
Jan 11, 2018 10:05 AM
