Radiator Fans and Other Components
Old Nov 11, 2017 | 01:26 PM
jnelso61's Avatar
jnelso61
I just got a CSF triple pass radiator. Since I am upgrading my radiator should I also upgrade the fans? I was looking at Mishimoto and Flex-A-Lite fans. What is the best setup for radiator fans? Does this make a big difference? How about water pump and thermostat? Thanks.
Old Nov 12, 2017 | 10:51 PM
slartibartfast's Avatar
slartibartfast
If you're not overheating now, then your fans are fine. I don't hear of thermostat or pump problems.
Look for a higher pressure cap, though.
Old Nov 13, 2017 | 12:09 AM
jnelso61's Avatar
jnelso61
Thanks Slartibarfast. The CSF radiator comes with a cap and I think it's high pressure. Sounds like all I'll need now then are the hoses and the radiator then.
Old Nov 13, 2017 | 10:05 AM
Waste86's Avatar
Waste86
Before you install the CSF you may want to check with Defpoint or some similar name on 370z board. There have been issues with the CSF radiators (mine included). My threads had to be retapped on it.
Old Nov 13, 2017 | 11:13 AM
jnelso61's Avatar
jnelso61
Got it. Yea I've been a bit worried reading the QA threads. Were the issues with yours immediately apparent or did you start having issues after a while?
Old Nov 13, 2017 | 12:31 PM
Waste86's Avatar
Waste86
After a while. Noticed that coolant had blown past a gasket at one point. Saw dried coolant around the hole. Hadn't lost total system cooling, but was still annoying.
As an answer to your previous question, I don't use aftermarket fans and have never had an overheating issue. I don't know if you are tuned or not, but with my tune my fans are programmed to come on earlier.
Old Nov 13, 2017 | 03:57 PM
slartibartfast
The fans don't operate until a certain temperature is reached. Most street driving won't trigger the fans to run. Track will, stop-and-go will.
Old Nov 14, 2017 | 05:37 PM
jnelso61's Avatar
jnelso61
But would you say that the fans need to be upgraded or do they seem fine?
Old Nov 14, 2017 | 09:10 PM
slartibartfast
I personally wouldn't worry about them.
Old Nov 15, 2017 | 10:51 AM
Waste86's Avatar
Waste86
There are people running twin turbo kits on stock fans and stock radiator. I wish I had known this before I went CSF and saved myself money and headache.
