Possibly a transmission problem, need help
Old Dec 4, 2017 | 03:11 PM
pat_0701's Avatar
pat_0701
Sidenote: This is my first post, I've already tried searching the forums for this problem.
I own a 2010 G37s Coupe 6mt. Recently I've been having a strange problem. When accelerating (above 4000 rpms) I notice that my shift **** shifts to the right very violently (when I'm in gear). Along with this, there seems to be a squeaking noise (similar noise if you rub a finger against glass) coming from what seems to be the front. This sound also erupts when I put just a little more gas (1300 rpms) than usual when driving off in first gear. I have a feeling this might be because of my shift linkage.
Also: When I turn left, there seems to be a loud popping noise coming from the front drivers side of the car. I took my wheel off to try to diagnose this problem but I did not see anything wrong.
Any help would be greatly appreciated!
Old Dec 4, 2017 | 06:21 PM
slartibartfast's Avatar
slartibartfast
My first thought is broken motor mount.
Old Dec 5, 2017 | 02:09 PM
pat_0701's Avatar
pat_0701
I will look into it to see if the engine moves when revving. Thanks!
Old Dec 14, 2017 | 06:33 PM
pat_0701's Avatar
pat_0701
Update: Not my motor mounts, the wobbling noise and shifter shifting to the right in gear have both stopped strangely enough.
But I get a popping noise coming from the front when flooring it 1st and 2nd gear. Doesn't happen when in 3rd gear and so on. I tightened my sway bar end links but still didn't fix the problem.
Anyone have any similar issues?
Old Dec 15, 2017 | 04:13 AM
Jonesmeister11's Avatar
Jonesmeister11
Try manually shaking your motor. Like grab a hold of it and man handle it and shake it. On my g35 I had a bad motor mount that only made noises when going over speed bumps, heavy acceleration, and shaking the motor. Reving without Load didn't make a knocking noise if I recall.
Old Dec 15, 2017 | 07:07 PM
pat_0701's Avatar
pat_0701
Tried shaking it by hand, motor would not budge. This noise only happens in 1st and 2nd gear. Car has 60k miles on it if that would help.
Thanks for the reply though!
Old Dec 21, 2017 | 11:10 AM
Surfnazi's Avatar
Surfnazi
Check trans mount
Old Dec 21, 2017 | 01:58 PM
slartibartfast
The trans mount has soft rubber. You'll probably have to remove it to see if it's bad.
Old Dec 21, 2017 | 05:04 PM
Jonesmeister11
Anyone have instructions on how to replace the trans bushing? I checked z1's website and they said instructions are set with the product.
Old Dec 21, 2017 | 06:34 PM
slartibartfast
It's all of four bolts. Two mount-to-chassis bolts and two mount-to-trans bolts.
