Bad sensor?
Old Jan 28, 2018 | 02:44 PM
lausellduane's Avatar
lausellduane
Exclamation Bad sensor?
Hi everybody my name is Duane. My 6-speed manual g is having a misfire that causes the car to choke when it reaches 2400 rpm. When it reaches 2400 rpm exactly it doesn't let me speed up beyond that i had to take the battery off then put it back on so I could drive it to get back home. I have took it to like 4 mechanics already and they don't know what exactly is the problem. When they scan it it just show multiple communications sensor error code. If you know whats happening please help.
Tks,
Duane
Old Jan 28, 2018 | 03:25 PM
PNW_IPL's Avatar
PNW_IPL
4 mechanics need a new line of work lmao. Take it to a dealer with a competent service department.
Old Jan 28, 2018 | 03:51 PM
telcoman's Avatar
telcoman
Tks,
Duane
Limp mode prevents severe engine damage
Telcoman
Old Jan 28, 2018 | 04:03 PM
lausellduane
Tks that's exactly what's happening! Do you know how much it can cost to fix?
Old Jan 28, 2018 | 04:50 PM
Bommerang's Avatar
Bommerang
Yeah your car is in limp mode in order to protect itself. Try to pull the codes if you can and tell us what they are, if you've already reset the battery multiple times and it keeps going back into limp mode something serious may be happening. The codes will give us alot of insight, also post if you have any mods done.
coastalsquirrel
Dec 13, 2014 08:09 PM
RISKY GUY
Apr 26, 2013 11:58 PM
PR_G37
TSB - Technical Bulletins
Aug 23, 2011 04:22 PM
sobi6111
Oct 22, 2010 03:52 PM
