$20 Diff Bushing Fix
Old Dec 29, 2017 | 08:24 PM
MotorvateDIY's Avatar
MotorvateDIY
I did post this video in the DIY section, but I thought it has a better chance of saving money for anyone who has a ruptured / blown diff bushing if posted in the general section.
Old Dec 29, 2017 | 09:27 PM
Infin88's Avatar
Infin88
Love and appreciate all of your videos.
Would you suggest doing something like this as a preventative measure before any rupture happens?
Old Dec 29, 2017 | 10:02 PM
MotorvateDIY
Infin88: Thanks for your kind words about our videos!
If you bushing has not ruptured, I wouldn't do anything. After all it is still working as designed. BUT if you notice drip marks on your subframe or exhaust, this is a quick and easy fix.
Old Dec 29, 2017 | 11:50 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Great idea! I believe this is what you used.
Amazon Amazon
Wonder if there's a 3m or permatex equivalent.
Old Dec 30, 2017 | 08:20 AM
Very clever and practical, and truly excellent under-the-car video. You certainly deserve compliments for this one, OP.
I said this in the DIY thread, and say it here too... I think you should go ahead and replace the two side bushings, since they're a relatively easy swap, and you already have them. I believe it was 4DRZ who did the side bushings months before the main one, and was surprised to notice the changes just from those alone. The theory is that the main bushing is holding the weight with vertical compression, but the side bushings actually take more abuse as the drivetrain twists. Right, wrong... IDK. But putting the idea out there anyway.
Go back to your video and watch the right side bushing movement.
What, intentionally cut the bushing? Yikes!
The best thing you can do prevantatively is swap the bushing before it ruptures. I had that done while the diff was down for a gear swap to a shorter 4.083 final drive, more for peace of mind than because it was needed. And honestly, I wasn't sensitive to any change afterwards with the poly mounts. But my OEM mounts were fine and only had 35k miles on them, so I guess that makes sense.
Try not to worry too much about this happening. There's no urgency or emergency if it does. It's not a safety issue. Lego went a whole year with his main diff bushing blown.
Old Dec 30, 2017 | 10:23 AM
Lego_Maniac's Avatar
Lego_Maniac
Nice fix. This is a pretty common approach. Way back in the 90s when I had a Neon R/T, this was the technique used to fix the front motor mount.
Good work. This will undoubtedly save someone some $$
Old Dec 30, 2017 | 11:27 AM
MotorvateDIY
https://www.amazon.ca/LePage-Instant.../dp/B019GISEHW
That is exactly what I used.
Almost any kind of polyurethane could be used.
I chose to use 5-minute epoxy as it is easy to find and inexpensive.
Old Dec 31, 2017 | 01:19 AM
staskz's Avatar
staskz
gotta say its a great temp fix for those not wanting to mess around with the diff! cool tip
Old Dec 31, 2017 | 04:50 PM
JSolo's Avatar
JSolo
Just say no!!!!!
If that epoxy holds up, it might be more than a temp fix. We'll revisit in a year
Old Jan 3, 2018 | 07:50 PM
AARONHL's Avatar
AARONHL
You could even buy some syringes on ebay and load the epoxy into it
Old Jan 3, 2018 | 10:00 PM
Gio37's Avatar
Gio37
This epoxy also comes with an applicator
LINK LINK
Old Jan 4, 2018 | 11:42 PM
takeapieandrun's Avatar
takeapieandrun
Wow, really cool; thank you. I had resigned myself to having a blown bushing (I haven't checked, but my car has 100K miles so surely it is blown), but this would be a super easy fix to do along with my sway bar bushing replacement.
Old May 10, 2026 | 11:44 AM
mumps67's Avatar
mumps67
This is great even for someone who does not ordinarily work on cars. I borrowed some ramps from a friend and somehow managed to get the car up on them. The Lepage epoxy is the exact equivalent of the Loctite pictured below. The bushing had more oil still left in it than expected and I tried to get as much out as possible. Mostly the technique worked fine although it took more pressure to get the epoxy in the bottom opening and the opening created in the top would not accept hardly any epoxy at all. There are no videos or pictures of any of this as I don't have a way to do it in such a tight space. The car ended up sitting for 48 hours to let everything fully cure. With no pictures or videos there is no way to prove the procedure worked, but I feel a difference. The car used to feel like it was moving around even when stopped. Now everything is solid and right again.
b2autodesigns
Drivetrain
259
Mar 29, 2018 11:55 AM
MotorvateDIY
Jan 22, 2018 05:27 PM
Synolimit
Oct 21, 2014 08:59 AM
oro
Mar 31, 2013 04:55 PM
6mtg37s
26
Nov 3, 2011 04:26 AM
