08 6mt, 5th gear slight grind
Old Aug 2, 2011 | 01:01 PM
Drag-Goon's Avatar
Drag-Goon
I just picked up an 08 G37 and the car is a beast. I still have to take pics and post them. I just haave a quick question and a concern. I've noticed that sometimes when I shift into 5th gear there is a slight grind and the funny thing is it doesnt happen all the time. It seems when i'm really pushing the car from stop from 1st gear when I get to 5th gear I hear a slight grind. Now I have to test it out more but I think at high rpms is when I have the grind. When I drive normal I hear no grind when going into 5th.
Anyone else have a problem like this? I've searched the forums and it seems no one else really has the same problem as me. Appreciate the help.
Old Aug 2, 2011 | 01:32 PM
Swacer's Avatar
Swacer
Its likely that its a syncro problem with 5th gear. It either will stay the same if you dont' press the issue, but could get worse overtime.
I had a similiar issue with my Genesis Coupe. Hyundai replaced the entire transmission. From what I've been told, Infiniti and Hyundai are using the same transmission builder (which worries me because I'm getting rid of that curse of a Hyundai and getting an IPL) and I'd prefer not to run into those problems again.
Is the warranty transferable for Infiniti? If so, I'd take it to the dealership and take one of them for a ride and reproduce it. I have a feeling a tranny replacment is in order for you.
Good luck.
Old Aug 2, 2011 | 01:39 PM
Drag-Goon's Avatar
Drag-Goon
Its still under warrenty, it only has 49k miles on it. Looks like im going to have to take it to the dealer today. Sucks bc I jsut bought the car.
Old Aug 2, 2011 | 02:00 PM
Drag-Goon's Avatar
Drag-Goon
Oh by the way. Is there a method from keeping this happening again? They will probably replace my tanny but I would like to know how to keep it from happening again.
Old Aug 2, 2011 | 02:12 PM
stormgate's Avatar
stormgate
granny shifting...
Old Aug 2, 2011 | 02:18 PM
Drag-Goon's Avatar
Drag-Goon
Originally Posted by stormgate
granny shifting...
LOL, not in this car. The g37 wants to move.
Old Aug 2, 2011 | 02:25 PM
Swacer's Avatar
Swacer
Really, depends on the severity. In my first transmission, the 5th gear grind wasn't bad. So in granny shifting, it would shift smoothly.
After that transmission was replaced, my second one started eating up the 3rd gear syncro until it eventually blew the tranny up. It didn't matter how I shifting, it would grind severely. So it depends how bad it is, in terms if you can avoid it or not. For the 3rd gear, the day it happened, I just started shifting 1-2-4-5-6. It sucked. (Wonder why I wish to get rid of it? haha)
I wish you the best of luck in getting it replaced. Don't accept "we can't duplicate the problem".
Old Aug 2, 2011 | 02:31 PM
Drag-Goon's Avatar
Drag-Goon
When I granny shift it doesnt happen at all. It just when I really want to move the car in and out of gears. My question is what would you do if it were you?
Old Aug 2, 2011 | 02:59 PM
Swacer's Avatar
Swacer
Well, you have a powertrain warranty, utilize it.
If you like the car, and plan on keeping it around, it won't be much fun if you hate shifting into 5th.
Old Aug 2, 2011 | 03:13 PM
Drag-Goon's Avatar
Drag-Goon
good point.
Old Aug 2, 2011 | 03:56 PM
MSCA's Avatar
MSCA
If you don't beat on the transmission, it should be fine. The harder you work the synchros, the faster they tend to wear out. Once they are worn to a certain point, you'll start to get grinding when you shift gears.
Old Aug 3, 2011 | 12:40 AM
voltic's Avatar
voltic
Yeah, my 2nd gear synchro is iffy right now. I personally wish it would get bad enough to where I can get it warrantied and be done with the problem altogether, but if you want to make it last just shift slow and careful.
Old Aug 3, 2011 | 08:34 AM
Swacer's Avatar
Swacer
How many miles?
Old Aug 3, 2011 | 07:49 PM
voltic's Avatar
voltic
It started around 10,000 or so.
Italia311
Jun 28, 2016 11:25 PM
Stevolkz33
May 28, 2016 02:36 AM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
VQCrew
Sep 26, 2015 01:19 PM
