car jerking
Old Jul 28, 2011 | 04:53 PM
myg37journyspor's Avatar
myg37journyspor
car jerking
I have a G37 sport, 2008. Every once in a while I have this jerking sensation in the car; like when I am trying to stop at a light; the care wants to keep going; jerking forward. I have after market exhaust and cold air intake.
any suggestions?.
this just happens once in a while; cheap gas maybe?
Old Jul 28, 2011 | 05:07 PM
_ant_'s Avatar
_ant_
cheap gas, problem with maf?
Old Jul 28, 2011 | 05:09 PM
pauliewalnutzz's Avatar
pauliewalnutzz
Ac is on??
Old Jul 28, 2011 | 05:14 PM
pauliewalnutzz
any suggestions?.
Very funny threads today.
Old Jul 28, 2011 | 05:22 PM
Weiboy718's Avatar
Weiboy718
Transmission is down gearing. That can cause a slight push too
Old Jul 28, 2011 | 06:07 PM
myg37journyspor
Yes, I live in houston so AC is always on; what is maf?
Old Jul 28, 2011 | 06:11 PM
eksigned's Avatar
eksigned
jerking sensation in your car eh?
probably the car downshifting.
Old Jul 28, 2011 | 06:32 PM
ANMVQ's Avatar
ANMVQ
There are threads on here about the car lurching forward when down shifting. I think there is a tab
For it?
Old Jul 28, 2011 | 06:41 PM
myg37journyspor
so even if the car is downshifting; should it "lurch" that much?, can anything be done to smooth it out?
Old Jul 28, 2011 | 08:02 PM
Soliditude's Avatar
Soliditude
If what you're describing happens to be exactly as how I'm imagining it, that's completely normal for an '08 5AT coupe. My car does exactly the same thing, especially if I completely let off the throttle at around 40-MPH. The G37 has an ability to sort of engine brake itself, and the side-affect of that is the slight jerking. I checked it out with the dealer back in the day, and they said it's normal for the 5AT's as well. You have nothing to worry about.
Old Aug 6, 2011 | 08:05 PM
Booboo's Avatar
Booboo
Light jerking is normal before coming to a complete stop but if the RPM stays high then take your car to the dealer to have it reprogram at no charge. That happened to my car (RPM sometimes stayed high, 1100 RPM at stop when shifted to Neutral). Good luck
Old Aug 6, 2011 | 08:07 PM
tharbemiko's Avatar
tharbemiko
Yup transmission downshifting. This "jerking" only occurs when you brake harder than normal.
Thedbarz
33
Feb 9, 2016 12:05 AM
SLEV3N
General Tech Questions
Oct 17, 2015 05:58 PM
JoshB
Oct 15, 2015 03:08 PM
MeatySock
Aug 14, 2015 08:25 AM
350zrunnin12s
Aug 9, 2015 09:55 PM
