R2C install help!
Old Aug 5, 2011 | 10:48 PM
R3diK3r0u5's Avatar
R3diK3r0u5
R2C install help!
i can't figureo ut how these crossover tubes are supposed to be connected of either the passenger or driver side?
i checked out this install but my tubes appear to be in different locations
Infiniti G37 R2C installation instruction how to.
so how are these supposed to be connected?
Driver side
Passenger side
Old Aug 5, 2011 | 10:57 PM
kool_yaar's Avatar
kool_yaar
Did you get these R2Cs used or new? It seems as if you have the G35 Sedan in which case you need a "fitment kit" which ships with R2C intakes.
This allows for you to remove those big breather elements(rectangular black boxes where the pipe connects with the intake) and replace with a Y connector on the driver side and a 90 degree elbow on the passenger side that they send which make is it easier to connect.
If you bought it used from a G37 owner then they might not have the kit since they dont require the 'extra' connectors to install these in their cars while we need em.
Hope that helps
Old Aug 5, 2011 | 11:08 PM
kool_yaar's Avatar
kool_yaar
g35driver.com FTW! lol
Old Aug 5, 2011 | 11:10 PM
R3diK3r0u5's Avatar
R3diK3r0u5
man you've gotta be kidding me... i bought it new from a vendor on here and that wasnt shipped to me...
i have to drive from college station to houston tomorrow morning so now i have to put my stock intakes back on...
i guess it was never specified in our PM's but i feel like that should have been something i was asked
Old Aug 5, 2011 | 11:25 PM
kool_yaar's Avatar
kool_yaar
Well when i didnt have the kit i just 'looped' the pipe over the intake tube and connected just fine(hope that makes sense) and drove like that for a week before i got the kit. Basically you can make it work if you want for a little while but tape the intake tubes with painters tape to avoid scratches.
Old Aug 5, 2011 | 11:32 PM
R3diK3r0u5's Avatar
R3diK3r0u5
could you explain that in a little more detail?
on the passenger or driver side?
Old Aug 5, 2011 | 11:36 PM
Tunerz_Store's Avatar
Tunerz_Store
Parts Specialist
There is no reason to ask for that piece as it should have been included in the package for the G35 specific kit that has a separate part number from the G37 intake. In this case unfortunately, it was overlooked when everything was packaged up in warehouse.
Old Aug 6, 2011 | 12:03 AM
Tunerz_Store
Parts Specialist
Isn't the top picture the driver side and bottom picture passenger side? I know I'm not crazy...
Old Aug 6, 2011 | 12:53 AM
R3diK3r0u5's Avatar
R3diK3r0u5
haha yup youre right, fixed. well the stock intakes are back on. at least i know what im doing now and my install once i get the fitment kit should go quite fast!
Old Aug 6, 2011 | 08:53 PM
kool_yaar's Avatar
kool_yaar
its should be an easy install with the kit but let me know if you run into any problems. g/l
Old Aug 11, 2011 | 08:22 PM
R3diK3r0u5's Avatar
R3diK3r0u5
so i received my fitment kit and about have the intakes on but done have enough clamps for that tubing. @kool did you clamp all of them or leave them like they were in your photo? currently i used the screw clamp to attach the hose to the intake tube, then no clamp on the hose to 90 degree elbow, then a clamp on the 90 degree elbow to the tubing on the car. driver side is similarly set up. will this be fine or do i need to go get clamps for those missing connections?
Old Aug 11, 2011 | 09:24 PM
Tunerz_Store
Parts Specialist
I don't believe those kits come with clamps.
Old Aug 11, 2011 | 09:53 PM
kool_yaar's Avatar
kool_yaar
Dont worry about it, i havent had any clamps on those tubings for over 2 years now with no issues, they are still on tight. Just make sure when you install it you push it up as much as you can and check them for a week and you should be good.
Basically what you see in my pics is how i left it without any issues.
superjoey
31
Mar 22, 2023 11:56 PM
drewfinity
Sep 25, 2015 04:08 PM
jsheets
Sep 3, 2015 07:33 AM
cparise
Aug 19, 2015 01:51 PM
