Help starting issues stillen supercharger
Old Apr 21, 2014 | 07:15 AM
vlad147's Avatar
vlad147
Hi
stillen supercharger 850cc injectors 340l fuel pump
sometimes when starting i need to press the accelerator to start. On these occasions a small amount of bluish smoke comes out of exhaust. My tuner said it is to do whith the 850cc injectors and is awaiting a response from uprev,which does not seem to be forthcomming in a timely manner. I also get a bit of cycling in revs when cruise control engaged at around approx 2.2k revs 100klm /hr.
Does anyone have any suggestions or has encountered these issues.
Thanks in advance
Old Apr 21, 2014 | 07:52 AM
ANMVQ's Avatar
ANMVQ
Hey MAN
Did you have it Retuned yet. An the sometimes is when you have been driving already right? There is an issue with the "hot" start tables. Mine had it also, So bad the car would actually food out . The retune will take care of that.
Old Apr 22, 2014 | 04:10 AM
SPDCRZ's Avatar
SPDCRZ
A tune will fix it. I had this issue with warm starts. Starting the car after turning it off within 15 or so min.
Its not a big deal, just let the engine cycle completely before turning the car over. You should be able to hear the fuel pump turning over and then stop. When it stops you should be able to turn it over without having starting problems.
Old Apr 22, 2014 | 06:06 AM
vlad147's Avatar
vlad147
Thanks for the heads up, getting the impeller upgraded next week and uprev maf's installed, then get my tuner to look at the starting issues while re-tuning
filipinowise
Intake and Exhaust
Sep 24, 2015 04:18 PM
moy92
Aug 20, 2015 08:43 PM
moy92
Aug 19, 2015 05:30 PM
Jensen Mathew
Aug 16, 2015 08:06 PM
370gt253
Aug 11, 2015 12:44 AM
