Rusty clutch bleeder valve
The bleeder valve on my ZSpeed HD CSC is quite rusty. I guess it was bound to happen given that it just hangs outside of the transmission
What should I do to ensure I don't break it when I go to bleed it in the near future?
.What should I do to ensure I don't break it when I go to bleed it in the near future?
I think I'll try cleaning it up on the car first, with the bleeder closed and without removing it. Replacing the bleeder is a good idea, I'll look into sizing of the bleeder.
I am hoping it is surface rust, but my fear is that rust has formed in the threads and may give me a hard time when I go to crack it open. Would it be okay to use some PB Blaster on it before opening it? I believe it would be, but would like some opinions. I would hope this would creep into the threads and make life a little easier.
Make sure you use the proper tool for the job. A well fitting 6 point socket could be used to break it loose. Use a flare nut wrench there after. A standard wrench only grabs on 2 sides. The flare nut wrench grabs on 5 sides.
I am thinking of using either a box end wrench or a flare nut wrench to hold the part closest to the line going to the CSC and a 6 point socket on the bleeder itself would be the safest to crack it all loose.
Success! I sprayed the bleeder with some liquid wrench and then worked on my brakes for a few hours so it would have time to soak and work. I used an 11mm flare nut wrench to hold the base of the bleeder and 6 point 3/8" socket on an electric impact gun to crack the bleeder loose.
stevo4756
Oct 9, 2015 01:54 AM
Mattimus
Oct 4, 2015 01:33 PM
r0cketm0nkey
Sep 27, 2015 01:34 PM
