Shifting gears in regular drive mode HELP!
Old Aug 27, 2014 | 12:47 AM
Gurp925's Avatar
Gurp925
Hey all, so the other day i opened up my dash and was fiddling around back there and did the "unmentionable", and now when i'm driving and i shift gears in regular drive it will shift gears, as if i was in DS mode. Any help would be appreciated.
Thanks!
Old Aug 27, 2014 | 02:38 AM
Gina's Avatar
Gina
Thanks!
You can still shift gears in D mode also. I will just went back to D mode after a few seconds or you can hold the up shift and it will went back to D mode right away.
Old Aug 27, 2014 | 09:08 AM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
I assume you mean you're using the paddle shifters to shift through the gears in D mode rather than using the paddles/stick in DS most. As Gina said, you can use the paddles to shift in D mode, to cancel, either flip the stick to DS and back, or just hold the right paddle for 5 seconds.
Old Aug 27, 2014 | 09:27 AM
monytx's Avatar
monytx
I didn't know you could hold it back to normal. When in D, mine switches back after a couple seconds.
Old Aug 27, 2014 | 09:55 AM
chris_s's Avatar
chris_s
that seems fairly obscure, is it actually documented? How long does it take to go back to auto mode on it's own if you just stop shifting?
I often drop a gear to do some manoeuvring then get annoyed when it doesn't go back to auto on it's own fast enough. doing DS-D is a bit cumbersome. Will try holding the paddle to see if it's any better. thanks!
Old Aug 27, 2014 | 04:52 PM
Gurp925's Avatar
Gurp925
I've never actually noticed you could shift in D mode that's odd, ive had this car for 3 years first time im noticing it.
Old Aug 27, 2014 | 09:06 PM
blackfunk's Avatar
blackfunk
Really? I'm about to revoke your man card.
Old Aug 29, 2014 | 10:50 PM
Gurp925's Avatar
Gurp925
Lmfao I'm usually in Ds mode that's why
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
redlinernyc
Feb 29, 2016 11:06 PM
gammamotors
44
Dec 31, 2015 12:48 AM
inspector94
Sep 8, 2015 12:57 PM
