Clutch problem!
Old Oct 13, 2014 | 09:06 PM
Ricio1991's Avatar
Ricio1991
Clutch problem!
I need some advice. So i was having issues putting my car into gear (2008 g37s 6speed) on friday night and i got a tow truck to town it and me without thinking it was really late i decided to drop it off at aamco witch i know theyre so expensive. Well i really wanted to leave it at a trusted mechanic instead but didnt think so i give it to aamco and they said they have to check it internally so they drop the trans. Ends up being i agreed and they diagnosed it for me and said i needed a new clutch, flywheel, master cylinder, and slave cylinder. So i thought it would be roughly 1500 or so but they gave me 4100 to fix it with all new oem parts. So now i commited a mistake because i cant afford 4k so ima just pay 465 of labor and take it to my local trusted mechanic. I heard oem flywheel and clutch run alot at the dealer so i found used ones at z1 motorsports from ppl that upgrade with low mileage. I have not much of a choice would it be recommended to take that chance and buying it used because i don't have 2000 for a new oem clutch and flywheel? Please help if possible
Old Oct 13, 2014 | 09:27 PM
Ricio1991's Avatar
Ricio1991
Car has 85k original miles on it no performance mods
Old Oct 14, 2014 | 10:02 AM
Sunny G's Avatar
Sunny G
There are so many aftermarket options that can get you everything for less than $2k. As a matter of fact you can get a clutch and flywheel combo for around $800 for the JWT. Check the drivetrain section of the classifieds and see all the options other than OEM.
Old Oct 14, 2014 | 10:13 AM
chilibowl's Avatar
chilibowl
Master and Slave Cylinder shouldnt run you anymore than $130
Old Oct 14, 2014 | 10:57 AM
Sunny G's Avatar
Sunny G
A link you might find informative. Contact them for a package price
https://www.myg37.com/forums/drivetr...r-special.html
Old Oct 14, 2014 | 04:34 PM
Ricio1991's Avatar
Ricio1991
Thanks man! So i found an alternative i went with jwt clutch kit and flywheel and got an upgraded slave cylinder for 325! Woo hoo i couldnt believe the infiniti oem was so expensive but i got a good price from concept z performance. I heard the flywheel is a little noisy but as long as its in good mechanical condition ill be fine! I got my clutch and flywheel for 830 after taxes
Old Oct 15, 2014 | 01:26 AM
Sunny G's Avatar
Sunny G
Glad I could help. Update us when you get your car running again
Old Oct 17, 2014 | 01:09 PM
Ricio1991's Avatar
Ricio1991
Well i have a problem I just picked up my car from aamco after replacing everything clutch flywheel and master and slave cylinder and it went into gear just fine and two miles later it doesnt want to go into gear again now im going back to see whats going on. Im so stressed about this situation i wonder what can be going on. They even replaced the hydraulic tubes! Oh god my infiniti is kicking me in the butt:-(
Old Oct 17, 2014 | 07:21 PM
Sunny G's Avatar
Sunny G
Check the fluids in both the transmission and clutch
Old Oct 17, 2014 | 07:23 PM
Sunny G's Avatar
Sunny G
Maybe you should try a mechanic that deals with Nissan strictly.
Old Oct 17, 2014 | 08:15 PM
Ricio1991's Avatar
Ricio1991
Thanks they supposedly fixed it now ima pick it up Tommorow and see how it runs
Old Oct 17, 2014 | 08:18 PM
Ricio1991's Avatar
Ricio1991
Have u ever heard issues on the shifter assembly on these? Seems a bit tough to get into 4th gear when i first had it and i got told it might be the gearbox? Just a question because i recently like 2mo ago i got told by aamco that it was probably the shift assembly because they said my transmission and clutch were fine at the time im wondering if i get a new shift assembly it would correct the problem
Old Oct 18, 2014 | 01:28 PM
Ricio1991's Avatar
Ricio1991
I got my car back this morning and its all back to running conditions :-)! The clutch kit feels awesome!
Old Oct 19, 2014 | 03:35 PM
Sunny G's Avatar
Sunny G
thats great to hear. Keep it running
stevo4756
Oct 9, 2015 01:54 AM
butwhatuptho
Oct 4, 2015 07:51 PM
MrRiv
Sep 29, 2015 04:59 PM
k19g37x
Sep 29, 2015 02:46 PM
r0cketm0nkey
Sep 27, 2015 01:34 PM
