My G37S coupe 6MT wont crank sometimes..
Hello Guys!,
I ran into a problem, when I push down on my clutch and press the start button the car wont turn on right away... it either waits 2-3 secs then cranks or it does not at all... Sometimes I have to try 3 times to turn it on. If anyone has this problem and knows a solution to it please let me know as it has been getting on my nerves lol. Thanks!
Check the clutch ignition sensor switch. It's the little relay switch that tells the computer that the clutch pedal is depressed so the ignition will fire. Located down on the pedal assembly. They fail from time to time and is a super easy fix. $20 or so from the dealer and 10 minutes of your time. Same thing happened to my old G35.
Digilog
Aug 17, 2015 03:54 PM
