Differential Service- Flush Rear And Front?
Old Sep 27, 2016 | 02:00 PM
drizzy315's Avatar
drizzy315
Exclamation Differential Service- Flush Rear And Front?
hey guys i own a 2010 g37x sedan with 50k and i have never done a flush on any of the differentials. My question is do i just do the flush on the rear or both ?
i hear the rear is the one used for the most part on awd, please if anyone can answer this ASAP
Old Sep 27, 2016 | 03:56 PM
gavingw's Avatar
gavingw
I did both, as effort and cost difference was minimal.
Yes, you could tell the rear needed it more.
Old Sep 27, 2016 | 03:58 PM
Selym's Avatar
Selym
By "flush", do you mean drain and fill?
Old Sep 27, 2016 | 04:43 PM
drizzy315's Avatar
drizzy315
yes drain and refill. im trying buy the gear oil locally is royal purple or mobil one 75 w 90 a good oil to use? i want to do 75w 90 for both i know the manual says 80 w 90 for front but its hard to find locally
Old Sep 28, 2016 | 02:26 PM
SonicVQ's Avatar
SonicVQ
My local dealer had it in stock for $10 per bottle. It is the factory fill, but it is NOT synthetic.
Many have used a synthetic 75W90 without issue. Use what you can find.
Old Sep 28, 2016 | 02:43 PM
Selym's Avatar
Selym
Whatever you do, be sure to use a GL-5-rated gear oil. I'd stick with the recommended viscosity, too.
Old Sep 29, 2016 | 02:03 PM
drizzy315's Avatar
drizzy315
so i i got it done used mobil 1 75w 80 and yes its rated gl5. used 75w 90 for both front and rear.
Jun 29, 2025 06:18 PM
socialconflicts
Jan 18, 2017 07:59 PM
AleW
Sep 7, 2016 05:51 PM
wmvG37
Sep 4, 2016 07:10 PM
Rr1982
Aug 29, 2016 08:30 AM
