Code p0725 popping up.... help
Old Sep 27, 2016 | 11:48 PM
Jah.37x's Avatar
Jah.37x
Can someone plz tell me how serious this code is
Old Sep 28, 2016 | 10:52 AM
ANMVQ's Avatar
ANMVQ
Year and mileage of car it looke like it could be a few things
Possible causes - Faulty Crankshaft Position (CKP) Sensor - Crankshaft Position (CKP) Sensor harness is open or shorted - Crankshaft Position (CKP) Sensor circuit poor electrical connection - Communication error between the Engine Control Module (ECM) and Transmission Control Module (TCM)
Read more: P0725 Engine Speed Sensor Input Circuit Malfunction
The P0725 Codes is triggered when Transmission Control Module (TCM) does not receive the engine speed signal from Engine Control Module (ECM).
The Engine Control Module (ECM) monitors the engine speed through the Crankshaft Position (CKP) sensor with the engine running, and send signal to the Transmission Control Module (TCM).
Old Sep 28, 2016 | 02:20 PM
SonicVQ's Avatar
SonicVQ
The ECU talks to the TCM on a network (called CAN). The TCM is not receiving the engine RPM signal from the ECU. Unless you have special tools (Consult 3 / CAN sniffer) you will need to take it to the dealer and have them fix it.
This is not a common issue (that I am aware of) and there is no simple fix, like resetting the ECU.
Has any work been done on the car before the code popped up?
Old Sep 29, 2016 | 03:38 PM
Jah.37x's Avatar
Jah.37x
It's a 2011 g37x
Jah.37x's Avatar
Jah.37x
Yes I have mods
Old Jan 10, 2018 | 03:46 PM
G37xBrock's Avatar
G37xBrock
Did you ever figure out what the issue was? My car is throwing this code amongst others as well
Old Sep 19, 2019 | 06:10 PM
aacocella1's Avatar
aacocella1
My 2011 sedan is throwing this code (P0725). My car hasn't stalled. Nothing seems serious. It's shifting just seems to lag sometimes. And when accelerating from a stop i have to push the gas pedal down further than usual to get it to go.
Just feels like it should be running better.
Anyone think I should get the ECM update before i think about replacing the camshaft sensor?
Old Jul 31, 2021 | 10:42 AM
nonlinearedits's Avatar
nonlinearedits
sorry to revive from
dead but I’m having the same issue except the car will die and an hour later start up and do the same **** again. What did yours end up being? I already did a new oem crank sensor
goldeneaglesvc
Feb 5, 2019 11:36 AM
drizzy315
Sep 14, 2016 01:29 PM
drizzy315
Sep 14, 2016 01:04 PM
Diode Dynamics
Lighting/Cleaning Products
Sep 2, 2016 02:11 PM
