Help Southbend Stg2 Clutch/flywheel / zspeed HD CSC
Old Sep 29, 2016 | 05:29 PM
911turbo's Avatar
911turbo
Hey everyone,
So we just installed my southbend stage 2 clutch with lightweight QUIET fly wheel. and Zspeed HD CSC along with new OEM CMC, + flushed / changed transmission fluid and rear differential fluid. w/ OEM Nissan MTF and Redline 75/90
I am getting a kind of "whine" throughout all RPM's.. and the cement truck sound at 1.5k (normal I believe)
But literally I can hear my transmission whine or whistle throughout all the gears and on the interstate at 80mph..
is this normal?
I have put only 115 miles on the new setup so far.
Old Oct 3, 2016 | 03:03 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Check the lower shifter boot is still in place, Probably out of place from the trans removal.
Old Oct 13, 2016 | 03:50 PM
jpowersjr2's Avatar
jpowersjr2
Or if it is there, check to see if it has rips in it. I know a fellow member had a similar issue and his was fixed by replacing the lower boot because it had a big tear in it.
Old Oct 16, 2016 | 01:45 AM
PongSanity's Avatar
PongSanity
That's clutch chatter. It's normal. If it's louder than "normal" in your cabin then your boot can be torn. Every light aftermarket clutch has clutch chatter. It's fine.
Ryne
Jan 19, 2017 02:25 PM
jedmonds
Dec 24, 2016 11:40 AM
TheNextoGo
Dec 5, 2016 11:30 PM
avol3xo
Nov 10, 2016 10:45 AM
G37X GraSdadow
Sep 29, 2016 10:32 PM
