Transfer case rear seal
Old Aug 4, 2016 | 10:42 AM
Mg37's Avatar
Mg37
Exclamation Transfer case rear seal
Has anyone ever changed the rear output shafts seal? I am trying to remove the output shafts yoke off the transfer case to change the seal but can not remove the nut that holds the yoke on. I am wondering if this is left hand thread or if it has red locktite on it so I am considering the torch as my last option. I am bending my long breaker bar and my 450 foot pound impact isn't working at 120psi.
I am also a very experienced mechanic and not afraid to pUT some heat to it.
Thanks guys
Old Aug 4, 2016 | 11:26 AM
Mg37's Avatar
Mg37
We have had this car for a month. I am going through the car fixing all the little issues so they don't become bigger. I am so far replacing the front upper and lower control arms, and tie rod ends. Replaced all fluids except the transfer case (will change after seal) with Schaeffer lubricants and am about to change the plugs next week.
Old Aug 4, 2016 | 05:27 PM
Mg37's Avatar
Mg37
Just looked in the service manual on another site and found that it is called a locking nut but doesn't specify if it is mechanic or chemical lock. If I don't get a response soon I will be heating the shaft nut to remove.
G37sPhoton
SouthEast
Dec 15, 2016 01:28 PM
samkon
Jul 25, 2016 08:19 AM
kyro840
May 29, 2016 02:49 PM
Ape Factory
May 17, 2016 09:04 PM
