Oil Sandwich Plate Recommendations?
Looking to grab an oil sandwich plate to keep an eye on the oil pressure. I've been reading some incredibly mixed reviews on Glowshift, Mishimoto and Mocal with half of them being excellent and the other half saying the rings were junk and they leaked. Anyone have any recommendations, or should I just get a T fitting?
Keep i mind that if you use a sandwich plate for oil pressure, you are measuring the oil pressure BEFORE the filter and not the actual engine oil pressure.
I suspect the difference is only 4-8 PSI, but I just wanted you to know
You might want to put on an adapter and connect the oil pressure switch and oil pressure sensor to the stock location.
The oil pressure port on the engine is a 1/8" BSP (British standard pipe thread), so you will need a T with three ports:
• 1/8" BSP male (to engine)
• 1/8" NPT (to gauge)
• 1/8" BSP female (to factory pressure switch)
Many people have put a T on the oil pressure port with out any problems, just try to keep the assembly as short as possible.
** Do not over tighten the T or engine oil pressure switch. The spec is 11 foot-lbs **
krazyfiend (01-02-2022)
Dude, thank you so much, I've been trying to find that information out for like forever. Would you use pipe tape to seal the threads? Is it possible to just get rid of the factory sender without throwing codes?
GlowShift 1/8 BSPT Oil Pressure & Oil Temperature Sensor Thread Adapter for 2012-2016 Scion FR-S Subaru BRZ Toyota GT86
^ This should be exactly what I need then, right?
(BTW: having the switch open, or disconnecting the connector is the same thing)
Then get a 1/8" BSP Male to 1/8" NPT Female adapter and just remove the oil pressure switch and connect the adapter and gauge to the engine.
It is best to use some type of thread sealant like Ultra Grey RTV Gasket Maker.
When you use teflon tape, there is a small chance a part of the tape can tear off and enter the oil passages.
Modme
06-04-2017 01:29 PM
mprog
05-06-2013 05:46 PM
shifter2600
04-28-2012 06:31 PM
