Replace Water Pump[ at 87,000 miles?
Old Feb 13, 2019 | 08:39 PM
Geol's Avatar
Geol
Angry Replace Water Pump[ at 87,000 miles?
Purchased G37 Seden in December 2018, with 84,000 miles on it. 60 days later, a water pump replacement to the tune of $1000. Comments to share?? Thanks.
Old Feb 13, 2019 | 09:59 PM
stealthee's Avatar
stealthee
Water pumps have a life span. Some people replace them as routine maintenance at 60k miles.
Old Feb 14, 2019 | 12:48 AM
JSolo's Avatar
JSolo
Just say no!!!!!
It's major surgery to get at the waterpump on this car. They do wear out and leak eventually. Probably not a bad idea to replace timing parts too (chains, gears, guides).
Old Feb 14, 2019 | 11:55 AM
teahead's Avatar
teahead
84k miles seems pretty soon-ish.
My G35 coupe that I had had 141k on the clock w/no WP issues.
Luck of the draw.
Yes, while you're in there, replace any tensioners, guides, thermostat, gaskets. You shouldn't have to replace the chains. That's just more $$$.
Old Feb 14, 2019 | 12:21 PM
JSolo's Avatar
JSolo
Just say no!!!!!
^^At nearly 100K miles, one would be foolish not to replace the gears/chains given the engine is already torn apart. It's like changing a CSC without changing the clutch on a higher mileage car.
Old Feb 14, 2019 | 12:50 PM
teahead's Avatar
teahead
Fair enough.
May be a good idea to replace the alternator too while you're in there. Maybe PS pump too.
Ditto the back timing cover gasket if it's a 2011 or older.
latino914
29
Nov 13, 2017 08:25 PM
nightmareuki
Jul 13, 2016 01:39 AM
m0nkey
General Tech Questions
Jan 14, 2015 10:35 PM
cjbuege
Mar 27, 2014 11:39 PM
who4ever
Oct 27, 2011 01:26 PM
