MPG goes down
MPG goes down
Recently, my 2012 G37's MPG goes down from 20.7 to 19.6. Everything is the same as before. I thought it might be the battery issue. It doesn't get better when I replace the battery. Is anyone know what may cause this issue? My car runs around 48k miles now. Do I need to replace the spark plugs or change the transmission fluid?
If you live in a major metropolitan area, you are subject to EPA gasoline blend changes. This alone can knock mileage down 10% or more. You didn't provide your driving style or distance driven to judge whether that has had an impact on your fuel mileage. Did you buy new tires? Have you kept up with inflation pressure after winter set in? Changed oil or oil brand or type? If you have a 6MT, maybe your clutch is starting to slip. Ad infinitum.
[Edit]I just noticed I assumed the OP to be a U.S. resident. Silly of me.
liftacar
Jul 14, 2014 01:29 AM
ayarj12
Mar 31, 2012 08:19 PM
Middlefingaz
General Tech Questions
19
Mar 4, 2012 03:15 AM
