GTM motor mount rebuild part number?
I've got the GTM motor mounts and need to replace the polyurethane bushings.
Anyone know the size or a source for said bushings?
A part number would be glorious!
Can't swap to a different brand because supercharger clearance.
Unless someone can recommend a different brand with the needed offset.
If all else fails, I'll have to pull one and measure.
But as many of you know, that's a major PIA.
Your best bet is to measure, these should not be hard to replicate since it's a poly barrel with 2 studs. So basically any mount with the right height and thread size should work.
David Gut
Jul 30, 2018 09:16 AM
IcebergG
18
Jul 4, 2009 02:44 PM
