Help G37 5at rpm drops then jumps back when letting go of throttle
Old Apr 15, 2021 | 04:50 AM
Virk370gt's Avatar
Virk370gt
Hi guys. I have an 08 g37 5at and ive recently had this problem where when im driving and let go of the throttle the rpms drop below 500 then jump back up and the car lurches forward. It does it in pretty much every gear but more aggressive in lower gears. Also it doesnt do it when cold seems to get worse the hotter the car is. Any help please. I have a video link below of the issue. Thanks
https://youtube.com/shorts/oL9dIik1WhM?feature=share
Old Apr 15, 2021 | 07:46 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Does the "jump" happen under braking? Also, how is your base idle- steady at 650rpm or does it settle higher?
Old Apr 15, 2021 | 08:00 AM
Virk370gt's Avatar
Virk370gt
No braking involved. The drop and the jump happens right after the throttle is released. My idle is at 750 sometimes 800rpm. I'm tuned with uprev also do idk if my tuner has set the rpm higher.
Old Apr 15, 2021 | 08:07 AM
ILM-NC G37S
I know some 2008/09's had idle issues where the idle would jump and the car would lunge. Infiniti released a technical bulletin to have the ECU relfashed. Being you are tuned this obviously would not apply.
Old Apr 15, 2021 | 08:09 AM
Virk370gt's Avatar
Virk370gt
could a vacuum leak cause this? I'm suspecting i have one but haven't got it checked. I have this weird stutter at 2k rpm too, almost like a misfire but no codes or CEL
Old Apr 15, 2021 | 08:25 AM
ILM-NC G37S
Yes, a vacuum leak can cause all sorts of engine performance issues. Same with intake air. Wouldn't hurt to make sure everything is clean and tight.
Old Apr 15, 2021 | 08:30 AM
Virk370gt's Avatar
Virk370gt
Alright ill get a vacuum leak test done. Also the rpm surging i believe (cant remember 100%) started happening after i cleaned trottle bodies and maf sensor. Ive done the idle air volume reset and all the other procedures but i dont think any of that made any difference. Also when i put the car in D it feels like its acceleraring more than it should, sometimes it even changes to second gear without me touching the accelerator pedal at all.
Old Apr 15, 2021 | 08:53 AM
ILM-NC G37S
Being that these symptoms arose just after you did some maintenance leads me to believe the issue lies somewhere in your work. I would double check everything you worked on and make sure all of the intake/vacuum/PCV hoses are secure and the clamps tight. Also, did you make sure the o-rings in the TB's were properly aligned and the bolts tight? Probably wouldn't hurt to repeat the IAVL reset as well.
I had all of those symptoms- including the unintended acceleration- and the TSB solved those issues for me. Being tuned, maybe your tuner has some input?
Old Apr 16, 2021 | 04:38 AM
Said Amir's Avatar
Said Amir
Check for any exhaust leaks, especially around test pipes if you have any.
Old Apr 16, 2021 | 08:37 AM
Virk370gt's Avatar
Virk370gt
i do have test pipes yes. Im gonna get both a vacuum leak and an exhaust leak test done.
Old Jun 12, 2021 | 12:06 PM
kingraj's Avatar
kingraj
any update ?
Satchel
Jun 10, 2019 01:14 PM
TakmaN
Oct 16, 2018 08:31 AM
Alagator28
17
Jun 8, 2018 02:51 PM
ohseedee
Jul 24, 2015 08:02 PM
joey_v
Sep 6, 2011 06:12 PM
