Throttle Body Spacer
Old Apr 17, 2011 | 12:00 PM
Jadex153's Avatar
Jadex153
Does anyone make a throttle body spacer for the G37? Thanks.
Old Apr 17, 2011 | 12:21 PM
Weiboy718's Avatar
Weiboy718
what's the point of adding a spacer on the throttle body?
Old Apr 17, 2011 | 12:27 PM
Doggy's Avatar
Doggy
I thnk it makes some noise, not sure though.
Old Apr 17, 2011 | 12:33 PM
Weiboy718's Avatar
Weiboy718
i really don't see a point in doing this just for the noise. noise of a air leak?
Old Apr 17, 2011 | 12:57 PM
mw09g37's Avatar
mw09g37
well back in the day.. they used throttle body spacers to increase the volume between the throttle and cylinder, improving volumetric efficiency. similar to plenum spacer.
but I believe modern cars with fuel injections already optimized for standard volumetric efficiency and you'd have to go to forced induction to get any more.
the most you'll probably get is a change in sound..... maybe but there won't be any benefit. but I don't think there is car specific ones out there,, just direct fit cause throttle bodies are kind of off the shelf now a days.
Old Apr 17, 2011 | 05:36 PM
Frankyg37s's Avatar
Frankyg37s
no point on the G37 its not like the G35
Old Apr 19, 2011 | 11:09 PM
blk_vr38's Avatar
blk_vr38
I believe improving the air volume post-tbody may slightly improve the top end power output of the car. This is why everyone was running manifold spacers on the VQ35, except the power improvement was marginal at best.
Old Apr 19, 2011 | 11:11 PM
Steveo47's Avatar
Steveo47
^^^ its done because its cheap and MAY do something. Like BB grounding kit. We really dont know if it does anything but we all buy it haha.
Old Apr 30, 2011 | 03:17 PM
zanzee's Avatar
zanzee
The intake manifold spacers are for stopping heat soak not adding more volume as they're usually 1/4t thick at most. I'm not sure it would do anything on our cars as we don't really have throttlebodys per say(not in the traditional sense anyways). The long tube intakes do seem to add more power then the shorty ram airs but that's probably just access to cooler air.
Old Apr 30, 2011 | 03:21 PM
jamesshifflett's Avatar
jamesshifflett
I was running plenum and throttle spacers on my maximum (VQ35) and felt gains on the top end but my bottom end (torque) dropped off, which on a V6 that's already lacking torque was kind of disappointing. Not sure on the effect on our engines though.
Old May 5, 2011 | 04:14 AM
Matthewyu's Avatar
Matthewyu
Throttle body spacer is a waste..
Old May 6, 2011 | 10:58 AM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
adding an extra inch or 2 to your throbble body isent going to do anything
linvbro
Aug 22, 2016 01:25 PM
Kojack
Oct 9, 2015 05:53 PM
faze2988
Oct 7, 2015 12:05 AM
VQCrew
Sep 26, 2015 01:19 PM
dedmanchan
Sep 24, 2015 11:25 PM
