Dirty Rear Differential Fluid?
Old May 14, 2011 | 07:38 PM
penciltop99's Avatar
penciltop99
Hello,
I took my car into the local Infiniti dealership today for an oil change and I was told that I have dirty rear differential fluid that needs to be replaced for about $80. Does this sound legit?
I have a 2010 G37 Sedan w/ about 29000 miles.
Thanks!
Old May 14, 2011 | 08:12 PM
$80 sounds like a good price to me. I don't know how they determined it was dirty though.
Old May 14, 2011 | 09:13 PM
dkmura's Avatar
dkmura
20 Year Member
I'd be a bit concerned with the report of "dirty" diff fluid. First off, how did they actually assess the condition of the fluid? Second, it's a high-pressure lubricant that doesn't usually change color unless it picks up some contamination from a mechanical problem. More details needed.
Old May 14, 2011 | 11:32 PM
penciltop99
I've never heard of this before and I wasn't able to research too much online. My owner's manual was stolen out of my car so I can't look it up...
Same place wanted to charge me $100 for replacing 2 air filters. I said no thanks, went ahead bought the 2 filters and replaced them myself.
I just want to know if the rear differential oil is something that you change often.
Thanks.
Old May 15, 2011 | 12:04 AM
AroundTheG37's Avatar
AroundTheG37
LMAO at the dealership charging 100 bucks for replacing air filters. IF anyone doesn't know how to change an air filter they deserve that bill and a kick in the *****.
Old May 15, 2011 | 12:08 AM
TVPostSound's Avatar
TVPostSound
Remove the fill plug, stick your finger in it!!!
Old May 15, 2011 | 12:13 AM
TVPostSound
Bearings, and gears wear, causing the fluid to darken.
I do my diffs at 1 year.
I did it the right way, on my back.
$18 for 2 quarts of Mobil 1 75/90 LS
$5 for the fluid transfer pump. They make one that fits standard oil bottles, and tall 90w quart bottles.
Yes mine was dirty at 14K.
Old May 15, 2011 | 12:15 AM
That's what she said!
Old May 15, 2011 | 12:18 AM
TVPostSound
hooters
Old May 15, 2011 | 01:05 PM
15951's Avatar
15951
Another "that's what she said" moment, brought to you by myg37.com
Old May 15, 2011 | 02:08 PM
kool_yaar's Avatar
kool_yaar
^+1, diff takes a lot of beating if car is occasional beat on, changing once a year yourself is a good practice, costs ~$20 for fluid and is a super easy DIY.
Old May 15, 2011 | 03:49 PM
eksigned's Avatar
eksigned
ugh...i just paid $60 to have my new rear pumpkin fluid swapped w/ some motul. eating the $60 because, the shop showed me how to do it. DIY is extremely simple.
Old May 15, 2011 | 04:40 PM
dkmura's Avatar
dkmura
20 Year Member
Bearings, and gears wear, causing the fluid to darken. I do my diffs at 1 year. I did it the right way, on my back.
$18 for 2 quarts of Mobil 1 75/90 LS, $5 for the fluid transfer pump. They make one that fits standard oil bottles, and tall 90w quart bottles.
I change the diff fluid once a year in my race 350Z because it uses a NISMO mechanical LSD and gets heavy use. The 75-90W synthetic fluid is already amber or honey colored as it comes out of the bottle. Draining will show some wear material on the magnetic drain, but rarely does it change the actual color of the fluid itself. I've also changed the diff fluid in my VLSD and follow the recommendations of 30K. No problem (or color change) there, either.
So I stand by my recommendation to the OP to get more info on what the tech found. Also, if you do replace the diff fluid, I'd highly recommend going with a synthetic (Mobil 1, Redline, Vakvoline, etc.) replacement for a few bucks more.
Old May 15, 2011 | 06:13 PM
soundmike's Avatar
soundmike
The fluid that came out of my differential was rather dirty, stank pretty bad, too. It had about 30k on it.
Old May 15, 2011 | 07:05 PM
spect2k's Avatar
spect2k
Is there a DIY for this on the forum somewhere? I'm sure it's very simple and I can see the drain bolt from the picture above. Where is the fill bolt?
