Help Quaife LSD Question
Old Mar 29, 2012 | 07:04 PM
vokhoa408's Avatar
vokhoa408
Quaife LSD Question
Hi everyone, I'm a total newb to the car modding scene and
was doing a little research on the 4.08 FD mod.
I'm looking to get it done to my car but I also want an after market LSD to go with it.
Doing some research, I've narrowed it down to Quaife as my brand of choice.
However I noticed that one of the vendors on this forum sells two versions for the g37 6MT.
https://www.myg37.com/forums/engine-...ood-price.html
Part #:QDF11L (Manual open rear end)
Part #:QDF13L (Viscous diff replacement)
Can someone enlighten me about the difference between the two?
I drive a 08 g37s coupe if that helps.
Thanks!
Old Mar 29, 2012 | 07:39 PM
TVPostSound's Avatar
TVPostSound
One is for a manual trans equipped car, the other is for an auto trans equiped car.
The ad is misworded.
Search: Cars, 350Z, Nissan, Differentials - Quaife Engineering
Old Mar 29, 2012 | 07:56 PM
vokhoa408's Avatar
vokhoa408
Getting what I can from reading the info on the link provided I see nothing about
the QDF13L (Viscous diff replacement) being for only automatics.
I see that the
QDF10L (Auto.) is only for auto.
I'm wondering about the difference between
QDF11L and QDF13L
Old Mar 29, 2012 | 08:15 PM
TVPostSound
I see that the
QDF11L and QDF13L
13 is a direct viscous replacement for both.
11 is a helical LSD for manual trans
12 is a helical LSD for auto trans
Why bother replacing a viscous for a viscous.
Even with helical the benefits shine on the track, not street driving.
Old Mar 30, 2012 | 02:35 AM
dimsler's Avatar
dimsler
Mainly because most viscous lsds, especially stock ones are dead after 50k miles and run like open diffs.
Plus the stock one doesn't handle the power very well and burns up, which also kills it quickly and reverts it back to open diff.
Old Mar 31, 2012 | 04:38 PM
TVPostSound
My statement was meant to state, why replace viscous with viscous, while your spending money for a swap, then get a true helical.
Old Apr 3, 2012 | 05:34 AM
oro's Avatar
oro
If I remember correctly Part #:QDF11L (Manual open rear end) is for cars that have an open diff from the factory. I remember seeing something about the hub length being different between the two. Longer hub is this one if I remember correctly.
Part #:QDF13L (Viscous diff replacement) This is for cars that came with a viscous slip in the first place and replaces it again, the only difference is the hub length for the two.
11 is for cars with an open diff, 13 is for cars that came with the limited slip.
Old Apr 6, 2012 | 06:34 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Open diffs and VLSD have different axle stubs so that is the part number difference. Jack you rear up and spin one wheel and if the other spins the opposite direction you have a VLSD.
I run a quaife it is a great diff if you do lots of street driving it doesn't lock up like clutch style LSDs. Mine has held over 610ftlbs of torque at the rear wheels.
Laguna
Oct 13, 2015 02:46 PM
Wreckreation
Sep 21, 2015 06:27 PM
GFTW
Sep 19, 2015 03:52 PM
gdaelemans
Sep 15, 2015 12:20 PM
gdaelemans
Sep 13, 2015 09:36 PM
