please help me , I install stillen gen3 intake my car too lean !!
Old Apr 19, 2012 | 05:38 AM
Modi-G37's Avatar
Modi-G37
Unhappy please help me , I install stillen gen3 intake my car too lean !!
I install test pipe on my car before 2 months , I get 288 whp on dyno jet .
After that I bought ARK exhaust and I get the same horse power 288 whp but my car was too rich 11.5 on high rpm .
finally, I install stillen Gen 3 , I get 305 whp but the car too lean in low rpm 14.7 and 13.6 in high rpm . What is the wrong ? should I remove the intake or tune ? What is the best chip ?
please help me , my car G37 sedan 7A-T 2010
Old Apr 19, 2012 | 06:48 AM
G37Sam's Avatar
G37Sam
It's normal, the intake pipe diameter changed and the airflow into your engine slightly increased. You will need a tune to adjust your AF ratio. Get in touch with an UpRev locally. Are you in the Middle East?
Old Apr 19, 2012 | 10:31 AM
Modi-G37's Avatar
Modi-G37
Yes, Iam from Saudi Arabia
Is there a dealer in Jeddah city ?
Is there a problem if I use car lean ?
Old Apr 19, 2012 | 11:50 AM
Buckeye G's Avatar
Buckeye G
Yes you can fubar your motor if you run it to lean. Check here..
UpRev - Engine Management
Old Apr 19, 2012 | 12:10 PM
redrover23's Avatar
redrover23
So the ECM is incapable of correcting for higher intake and exhaust flows?...thus requiring a tune?
Old Apr 19, 2012 | 12:16 PM
Buckeye G's Avatar
Buckeye G
That is corect. I think it will only do so much without a tune.
Old Apr 19, 2012 | 12:22 PM
redrover23's Avatar
redrover23
Interesting, thanks for the reply.
Old Apr 19, 2012 | 12:42 PM
G37Sam's Avatar
G37Sam
Oh Jeddah, that's gonna be quite a drive!
But if you do, there's are a few places experienced with tuning our engines using UpRev
Old Apr 19, 2012 | 01:42 PM
toyzforme's Avatar
toyzforme
Isn't 14.7 at low rpm actually still ok. It is where you get into the higher rpms that you need start worrying right? That is what I got out of the A/F ratio deal when I was tuning my Supra Turbo
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
BANNISTER
Dec 10, 2015 04:14 PM
ohmyg1990
General Tech Questions
17
Aug 13, 2015 08:18 AM
SpeedBallDEVIL
Aug 12, 2015 04:30 PM
