spark plug cost
Old Jul 30, 2014 | 06:17 PM
MPdesign's Avatar
MPdesign
Question spark plug cost
What has the dealer charged for new plugs and why are they so high?
2008 G37
Thanks
Old Aug 3, 2014 | 12:36 AM
jpowersjr2's Avatar
jpowersjr2
I'm not sure what the dealer charges but I work at AAP (Advance Auto Parts). The Denso Iridium plugs, FXE24HR11, are $14.99. I do however get an employee discount. I'll let you in on a little secret though. I buy everything, for the most part, online and use coupon codes. The coupon code TRT30 gives you 30% off and I have been using it for around 9 months.
Old Aug 3, 2014 | 01:49 AM
Spark plugs are an item that the vast majority of owners will only need to change only once in the life of their car. They are expensive because they're long life platinum or iridium plugs.
Old Aug 3, 2014 | 09:06 PM
ratso000's Avatar
ratso000
Which plugs are best, Im about to change mine at 80K?
Old Aug 4, 2014 | 02:23 AM
telcoman's Avatar
telcoman
Why at 80k?
Are you having a problem that required a spark plug change?
The owners manual recommends a plug replacement at105k miles
My plugs removed from my previous 06 G35 at 106k miles
Never try to fix anything that isn't broke
Telcoman
Old Aug 4, 2014 | 02:25 AM
telcoman's Avatar
telcoman
2008 G37
Thanks
The hourly labor rate at the dealer.
Telcoman
Old Aug 4, 2014 | 06:36 PM
ratso000's Avatar
ratso000
No problem car runs great....just figured I would change for good measure...
Old Aug 8, 2014 | 02:34 PM
mpegripper's Avatar
mpegripper
they are cheaper on rockauto usually, worth checking. only takes me less than an hour to change so i did it at 30k. that was way too early, next time will be at 80k (50k miles on the plugs)
Old Aug 15, 2014 | 01:34 AM
Track Bandit's Avatar
Track Bandit
It's starting to look like spark plugs are getting to be a non-maintenance item given the cleaner fuels and computerized engine management. That's okay with me.
Al
P.S. Also remember you don't have to buy these from the dealer. As you can clearly see the NGK or Denso brand on them and their part numbers, get them from a cheaper source. They'll be the same and work the same.
Old Sep 1, 2014 | 03:47 AM
cecrops's Avatar
cecrops
$21
I just rolled over the 70K mile mark and was looking to change my plugs too.
Rockauto has the AUTOLITE Iridium XP, Part# XP5682 @ $5.15 + $5 shipping with a handy rebate of $2.50 each, valid thru December.
Old Sep 1, 2014 | 10:01 AM
Adam West's Avatar
Adam West
My old Altima SE-R had 86k on it when I sold it, never changed the plugs and it ran like a top.
Old Oct 12, 2014 | 10:46 PM
NeverTooFast's Avatar
NeverTooFast
Ebay has some good sets for cheap, just make sure theyre a good brand and new
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
parkern
Oct 1, 2015 10:15 PM
Chappedj
Sep 28, 2015 03:20 PM
mikysee
Sep 28, 2015 11:18 AM
dedmanchan
Sep 24, 2015 11:25 PM
