ATF Drain and Fill Help, Fluid Spec
Old Jun 10, 2014 | 03:37 PM
G37AL99's Avatar
G37AL99
I think I have most of this down but just making sure. I'd like to do a drain and fill on an 08 G37 5 AT I picked up. Mileage is 75k. Flush seems dangerous to me and IV had good luck with drain and fills in the past.
I believe if I'm correct I need 4-5 quarts of Nissan S Matic?
Any other info I need?
Need any plug gaskets or anything?
Old Jun 10, 2014 | 04:01 PM
Redline37's Avatar
Redline37
If I recall, 4 quarts came out when I drained mine. Just simply drain from the bottom plug, and refill from the dipstick. Replacing the drain pan copper washer would be recommended to prevent leaks.
Old Jul 6, 2014 | 11:29 PM
jrb55gh's Avatar
jrb55gh
7AT fluid change
Changing the late model 7AT trans fluid requires a special tool and a specific procedure. It is described in the 2012 370z service manual available at:
https://www.dropbox.com/sh/bse3w8qwz3tuw9f/9DGHnXlN2W
My Nissan dealer wouldn't sell the tool to fill the transmission, so I made one. If you need more info PM me.
Old Jul 6, 2014 | 11:39 PM
Glover998's Avatar
Glover998
^ guy drives 5AT
vamarris
Dec 9, 2018 11:10 AM
faze2988
Oct 7, 2015 12:05 AM
MrRiv
Sep 29, 2015 04:59 PM
Murkr
Sep 28, 2015 10:45 AM
VIVID
Sep 27, 2015 09:45 AM
