Z1 Motorsports Clutch Concentric Slave Cylinder Elimination Kit for the 6MT
Old May 29, 2014 | 12:42 PM
Diego@Vossen's Avatar
Diego@Vossen
Found this very interesting.
With over a year in development and testing, Z1 Motorsports is now proud to offer a comprehensive, bolt on solution to the OEM clutch concentric slave cylinder for cars equipped with manual transmissions mated to VQ35HR and VQ37VHR engines. Thorough analysis and modeling of the factory clutch system's dynamics led to the development of an innovative kit that completely eliminates the failure-prone concentric unit, replacing it instead with a traditional release bearing mated to a Howe Racing pull-type slave cylinder.
Due to the repeated exposure to high temperatures and the high operating pressure of the factory concentric system, it has been considered a weak point of the HR+ platform’s revised drivetrain. These failures are definite, and the symptoms obvious; whether it’s pushing the limits on the track, driving hard on backroads, or simply commuting – if the clutch pedal sinks to the floor during a shift and doesn’t return, the concentric slave cylinder is the likely culprit.
Armed with an extensive list of design goals, product requirements, and functional benchmarks, the only solution was a no compromises approach. The Z1 Motorsports Concentric Slave Cylinder Elimination Kit has been extensively torture tested on the street and the track, and is completely CAD/CAM engineered as a bolt on solution to common clutch concentric slave cylinder failures, with no permanent modification to the drivetrain.
Standard VQHR+ CSCEK features:
Howe Racing Pull-type Cylinder:
Constructed of lightweight CNC machined aluminum and hard anodized black, this pull-type slave cylinder uses two dynamic bore seals, a preloaded return spring, and features zinc coated hardware and rod ends for seamless function and maximized longevity.
Dust and Heat Shields:
Laser cut from stainless steel and precision CNC bended to specification, these auxiliary brackets are included for the peace of mind and reliability that comes from keeping dust and dirt out of the bellhousing and keeping road debris and exhaust heat away from the slave cylinder.
Mounting Solutions:
Laser cut and CNC formed and machined, the mounting bracket and fork clevis were designed with the explicit goal of function. Several iterations of optimizing for stiffness and fatigue life resulted in the final revision, that features Class 8.8 zinc plated fasteners and no unwanted deflection.
Clutch Ergonomics:
Paired with the late-model heavy duty cast fork and a braided stainless steel clutch line, a properly installed and adjusted VQHR+ CSCEK will feel natural, with virtually no slop even under the most rigorous situations.
Inspected, assembled, re-inspected and packaged in house by Z1 Motorsports’ trained staff, the VQHR+ CSCEK arrives ready to install on your Z or G out of the box. In the dropdowns below, indicate the clutch that will be used, as well as any clutch fluid options. Transmission fluid replacement is recommended but not mandatory for the installation of this kit.
To view a complete copy of the Installation Manual for the Z1 Motorsports Concentric Slave Cylinder Elimination Kit, please download the PDF document Here.
Please note: Product will ship in 1-2 weeks.
Click Here To Order. Pricing starts at $418!
Old May 29, 2014 | 02:41 PM
kevshiau's Avatar
kevshiau
Finally an alternative for the CSC!! Will be purchasing after after a few reviews. Nice find
Old May 29, 2014 | 04:05 PM
Presto's Avatar
Presto
Waiting for reviews from other people with this. Few people on the370z.com have this installed.
I find this a better solution than the zspeed csc as this one is outside the transmission.
Anyone can chime in with their thoughts? Is it better to have the csc outside the transmission or not?
Old May 30, 2014 | 02:57 PM
kevshiau's Avatar
kevshiau
Is it recommended to also change the master cylinder with this?
Old Jun 4, 2014 | 12:46 PM
Presto's Avatar
Presto
Yes it is
TheLocNar
Dec 22, 2015 07:52 PM
claudiohv
Sep 17, 2015 01:43 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
inspector94
Sep 8, 2015 12:57 PM
