Thinking on adding a nos system to my G
Old Jun 9, 2016 | 09:45 AM
Jah.37x's Avatar
Jah.37x
Thinking on adding a 40-50 shot of dry what will I need to do it safe and not hurt the car
Old Jun 9, 2016 | 11:44 AM
iCrap's Avatar
iCrap
ok .
Old Jun 9, 2016 | 11:53 AM
Vizard_87's Avatar
Vizard_87
You have to watch for dangers to the manifold.
Old Jun 9, 2016 | 05:59 PM
empirepb48's Avatar
empirepb48
I hear a 32:1 mix of 90% isopropyl alcohol produces similar results. Oh, and don't forget to fill the windshield wiper fluid reservoir with taco bell hot sauce to keep all the bitches off your car.
: dancedancedancedancedancedancedance:
Old Jun 9, 2016 | 06:20 PM
slartibartfast's Avatar
slartibartfast
Dang, chilly reception for the FNG.
OP, you started in the wrong place. Google is your friend and it'll be happy to find info on adding N2O. Do want a wet or dry system? Are you going to use a bottle warmer and are you aware of the associated danger? Have you looked into the ECU programming?
Old Jun 9, 2016 | 06:47 PM
Mattlorentzoe's Avatar
Mattlorentzoe
Nitrous is totally worth it if you can install it yourself and then go get a shop to tune it with window switch. I was quoted around 2800 for everything bought and installed. That was for 100 wet shot
-purge, bottle warmers, gauges, electronic disconnect switch(in case of pull over), electronic on/off switch, tuned with window switch, ect
I totally would of done it if I could of installed all that myself and then the price would be less than half what I was quoted.
But honestly nitrous has been getting safer over the years but has to be done right. if I where do go nitrous route, direct port system seems safest(pita). Could be wrong plus not many ppl will want to by a car that had nitrous on it.
Also if you have a 7at, good luck that's going to need some upgrades more than likely also.
Old Jun 9, 2016 | 11:56 PM
1nceBitn2wceShy's Avatar
1nceBitn2wceShy
Adding a spoiler to the spoiler will increase HP as well.
12g37xs
Apr 4, 2017 01:35 PM
xnick101
Jun 9, 2016 11:40 AM
KARTMAN90
Jun 6, 2016 02:09 PM
ShuuraRG
Upcoming Events
Jun 5, 2016 05:05 PM
G10
Jun 4, 2016 11:40 AM
