Replacing transmission at 110k
Old Jul 6, 2016 | 02:20 PM
slotterjordan's Avatar
slotterjordan
So I got my 08 coupe at 88k. And it was fine. Then alittle after 5th gear would grind when I would shift fast. That was fine. Now all my fears grind when putting it into gear.. It drives. Just when I put the gesr in, it will grind. So my syncros are destroyed. I don't beat on it every day but I have raved and do spirited driving every now and then. But has anyone had any trouble replacing there's? How much you buy one for? Any tips?
Old Jul 6, 2016 | 02:29 PM
Is rebuilding your transmission not an option? Manual transmission replacement isn't particularly difficult. Are you DIY'ing or having a shop do it?
Old Jul 6, 2016 | 02:41 PM
Kris9884's Avatar
Kris9884
That's really weird, there are guys with these trans running 800hp+ in 2JZ cars without a problem. I bought one for $200 on Craigslist. I turned around and sold it for $750.. The swap is fairly simple with basic tools and some grunting.
slotterjordan
People told me rebuilding isn't worth it with this transmission. I can't find a rebuild kit or anything like that. I can get a used tranny for 800 or so. And my mechanic could do it for 300.
Old Jul 6, 2016 | 02:42 PM
slotterjordan
I've had my transmission out several times replacing slave cylinders ( 3 to he exact...) and master cylinder and clutch replacements. So getting a used one and getting that put in shouldn't be a problem.. I just hate that its grinning and only has 110k miles. But idk how it was driven before I got it at 88k miles
Old Jul 6, 2016 | 02:51 PM
Kris9884's Avatar
Kris9884
I have no doubt they were just rough on it or had a worn slave for too long and tore it up.
Old Jul 6, 2016 | 03:01 PM
slotterjordan
Yeah they could have just beaten on it and me beating on it doesn't make it better. And my transmission has been out 6 times with 3 different slaves. The third being my current one which is the heavy duty z1 slave cylinder. Because I have a aftermarket clutch and the pressure plate would break the slaves. And I've replaced the master twice. First time it broke 6 days after I bought it and I replaced it again because I put a new kit in my car and it weakened it apparently. So I've been through with this car already so it won't be the first. So I'll just buy a used tranny and just swap the clutches out and call it a day.
Old Jul 6, 2016 | 04:36 PM
Kris9884's Avatar
Kris9884
Sounds like a plan, are you gonna take apart this one to see what's up at all?
Old Jul 6, 2016 | 04:44 PM
slotterjordan
I mean with the way it grinds I'm almost certain it's the syncros so I guess there would be no point. Unless it's easy to take it apart? Like for my mechanic to do out of curiosity
Old Jul 7, 2016 | 09:04 AM
PongSanity's Avatar
PongSanity
My synchro gave out and now my transmission stuck in 5th gear. Everyone i spoke to has replaced and not repaired. hence what i did... bought an used one for 800 and will be installed tomorrow. If a shop has an used transmission, you can swap parts. But it'll be really hard to find a rebuild kit or transmission parts for the vq37vhr transmission. In your case, you was to change your transmission oil and you may have been fine... gonna use valvoline gear oil (75w-90) in mines for now til i get some motul/redline/amsoil gear oil
Old Jul 7, 2016 | 10:18 AM
slotterjordan
I hope I don't get stuck in a gear. My transmission oil was changed 10k miles or so ago. So I feel like it can't be that. And I bought oem Nissan oil. Was your gears grinding every shift?
Old Jul 7, 2016 | 11:41 AM
PongSanity's Avatar
PongSanity
No grind ever. At 57K.
Old Jul 7, 2016 | 12:37 PM
slotterjordan
And it just simply gave out?
Purist
May 4, 2016 11:46 PM
Mr.Moto
Apr 26, 2016 08:12 PM
msonbolg37x
Apr 20, 2016 08:29 PM
JohnsG37x
Apr 15, 2016 03:45 PM
pawel2009
Apr 10, 2016 11:48 PM
