7AT - cooler line cut in location?
Old May 14, 2016 | 05:22 PM
former520's Avatar
former520
I changed my transmission fluid at 120k and was shocked at how bad the fluid looked. I last had it changed at 80k at the Infiniti dealer.
I want to add in a transmission cooler. Where is everybody picking for a location to tie in the lines? I poked around a little and could not clearly see the lines.
Old May 14, 2016 | 05:59 PM
slartibartfast's Avatar
slartibartfast
Doesn't the radiator have the trans "cooler" built-in?
Old May 14, 2016 | 07:28 PM
stealthee's Avatar
stealthee
External cooler is extremely more efficient. On my Grand Prix trans temps dropped 40 degrees or more with the addition of an external cooler. The fluid is still running through the factory radiator cooler too. If it were run separate of the rad then temps would be even lower.
Old May 14, 2016 | 09:19 PM
slartibartfast
One of the reasons the fluid goes through the radiator is faster warm-up of the trans. The radiator should keep the trans fluid near 180ºF or whatever temp the thermostat opens. I would like to see actual temps in and out of the transmission.
Old May 14, 2016 | 10:22 PM
stealthee's Avatar
stealthee
And thats part of the reason I ran the external cooler in series. There was several occasions I saw 230 degrees on trans fluid temp. The highest I have seen since installing the cooler is around 194.
Old May 14, 2016 | 11:13 PM
former520's Avatar
former520
My plan is to run in series as well. When I lived in cold country, I would run the external before the radiotor so the transmission would not run to cold.
After seeing just how black and nasty the fluid was, I am going to run it after the radiator. I spend much more time in 110 plus rush hour traffic than I do in anything resembling cold weather.
I found the spot to hook into as well by looking at the instructions for the stilled kit. They are high in the engine bay and cannot be accessed from below.
Drivetrain
403
Mar 12, 2020 03:48 PM
g35aa
Jun 20, 2016 06:35 PM
Miami boy
May 20, 2016 02:52 AM
towerworld
May 10, 2016 02:31 AM
McStealth
12
May 5, 2016 07:56 PM
