Help! Metalic sound when revving.
Couple days ago when i was reversing into my house i pressed the gas pedal a little too quick and sharply. I heard a sound coming from the engine which sounds like a piece of metal clanking against something. I can do it on command as well. it only does it in neutral or parked... I attached a video of the sound here.
^^^^^what he said. check the shields on the cats and the headers.Cats especially are notorious for rusting around bolts and rattling. I live in a rust prone area and found a rattle from a plate on a harmonic balance near the tranny that had rusted and dislodged...rattled between 2800-3600 rpm on cue drove me nuts
Heat shield?? I don't think so. A heat shield would be more of a rattle.
My first guess would be the AC compressor clutch. Is the ac on? If so turn off and repeat.
Take a bright flashlight and follow the belt while someone else revs the engine. Observe the pulleys (or as many of them as you can).
It does it when the ac is off as well. I did tried to pinpoint the noise by using a bar and putting it on various spots. I tried pulleys but no go. I mean, you can hear the noise through a pulley but it's not that loud. The noise seems to the loudest when i put it on the front valve timing cover on the right... There's no codes being thrown though. I'm really hoping this is not an engine problem.
Yes, 72 months.
@sonicvq, you think it's detonation? I can't remember the last time i heard engine knock in a late model car. In older cars it sounded like marbles rattling in a can.
I would do, is contact someone at your local Infiniti dealership and make an appointment. What ever is going on with your engine it's a noise that should be looked at by a trained professional. Take the video and have them give it to the tech. I had a similar problem with another car and it ended up being the Cam shaft but their was a recall on it. Either way take it in ASAP
I really hope it isn't anything serious
