Help Engine oil g37s?
Old Nov 9, 2017 | 03:23 PM
Ernesto Arroyo's Avatar
Ernesto Arroyo
Engine oil g37s?
I know the vehicle takes 5w-30 but I was wondering does this vehicle take synthetic or synthetic blend?
Edit: i just realized I put thread on the wrong one
Old Nov 9, 2017 | 05:20 PM
slartibartfast's Avatar
slartibartfast
Put in whatever oil type makes you warm and fuzzy. They all lubricate. Cost is the primary difference.
Old Nov 9, 2017 | 09:27 PM
jrb55gh's Avatar
jrb55gh
Some formulations perform better than others in the face of real world adverse conditions such as low level coolant ingress, combustion blow by, fuel dilution, high oil tempratures. The advantages of these high quality oils show up after long mileage periods ie over 60k miles. No matter which oil you choose, change your oil and filter regularly and at 3k to 5k mile intervals. Also use a quality air filter (not hi flow) to keep the dirt out.
Old Nov 9, 2017 | 09:59 PM
Ricio1991's Avatar
Ricio1991
I use full synthetic pennzoil premium every 5500k no issues. You can use most reputable full synthetic unless you want to use conventional and change it every 3500k miles imo
Old Nov 10, 2017 | 04:30 PM
slartibartfast
Fully synthetic oils can last over 15k miles. At least the base stock can last that long. The additive packages are only good to about 8k miles or so.
One among many:
https://www.brianschreurs.org/neptun.../oil-life.html
Old Nov 11, 2017 | 10:44 AM
Victory's Avatar
Victory
Given the high temperature and oil shearing from the VVEL system along with my aggressive driving, i choose to use synthetic. Use whatever brand is on sale that month. You can easily go 5000-7500 miles on synthetic unless you track the car. Beyond that, i wouldnt push it without oil analysis to confirm the additive package is holding up
Old Nov 16, 2017 | 03:16 PM
Surfnazi's Avatar
Surfnazi
I use 5w20 castrol syntec and change it every 6k miles
Old Nov 16, 2017 | 07:36 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
I Have been using AMSOIL for 3 years.oil changes every 6 months love it
