Help! Clutch Problems
Old Sep 19, 2017 | 01:57 PM
TwistedIllusion's Avatar
TwistedIllusion
I'm having issues with my clutch pedal. In the morning there is no pedal. Let it warm up some and pump the pedal it comes in about 6 or 7 pumps. I changed the CMC and still the same. Not loosing any fluid, thinking slave, but usually when they go it starts leaking. Sticky pressure plate? Any suggestions would be helpful. Thank You
Old Sep 25, 2017 | 04:50 PM
jpowersjr2's Avatar
jpowersjr2
Sounds like the CSC. Is your clutch pedal on the floor?
Old Sep 26, 2017 | 09:14 AM
TwistedIllusion
Thank you for the reply, it was the CMC. I guess i hadn't bled the system all the way. Worked itself out after about 3 days.
