Hey guys, my car (2013 G37 coupe) threw a P2096 SES code and I'm not sure what to replace/fix to solve the issue, seems like it could be the passenger pre-cat 02 sensor from my research.
I'm running a Stillen CAI, Fast Intentions HFCs, and Ecutek tune which I've had on the car for about 30k miles with no issues till now. I've attached a screen shot from the torque pro app as well. I appreciate any help, thanks.
Will hold off with seafoam for now. It was most likely a leak, the passenger side post-cat o2 sensor was unscrewed a bit so I tightened that and everything else, cleaned the MAF, and cleared the code. Will see if that does it. Thanks again for the help guys
I suspect the issue is the high flow cats oxygen storage capacity has decreased below the ECUs threshold.
This is detected by the post-cat (sensor 2) O2 sensor.
To check, here is a video (using a G37) on how the rear o2 sensor voltage should change during different driving conditions:
Understanding & Live Graphing of the Rear O2 Sensor: OBD4Everyone Ep.19
Yup feed in SeaFoam through brake booster line. However, technically it's recommended you change out your spark plugs as well. That's what I did. Before I do an oil change I'll run some SeaFoam through the crankcase.
