MAP Sensor Failure? Error code P0106
So, I had a "Service engine soon." Light in March 2019, I checked what it was and it was error code P0106. I replaced the MAP sensor with a mechanic and they fixed it they put a new map sensor and I think reset the ECU? I think. The light was gone but recently it returned I got it again this month for the same error code? Could it be that the sensor is faulty? Anyone else have the same issue or is it just me ?
My advice is to always stick with OEM. I had an MAF sensor go out on my '02 Maxima (same code) at 200k miles. It may have just needed a cleaning, but I went aftermarket. It worked for a little while, but then the light returned. Same thing happened when I replaced a coil pack... went aftermarket and it still wasn't right. Everything worked fine once I used the original OEM parts. Also, handle the MAF sensor with care... delicate internals that can damage easily if dropped, etc.
That's good, he can return/exchange. I agree... OEM can take a dump out of the box sometimes. The problem today is that these parts (whether it be OEM or aftermarket) are made anywhere these days. I think there is a risk in quality when this occurs.
Michael Moheban
23
Mar 7, 2025 05:20 PM
lamchidinh
26
Jan 19, 2021 02:09 AM
