Help Clicking from rear when putting car in drive, reverse, accelerating
I cant find any video related to mine when i put the car in drive , reverse, hit the gas from a stop or come to a complete stop its one click that sounds from the rear middle of the car
Theres a TSB going all the way back to the 1st gen g's for clicking drive shafts(which i understand applies to the G37 as well), the remedy is to remove the axle and regrease the outer face where it meets the knuckle with the appropriate (moly) grease. The whole process is just an unbolt and RR affair should only take 15-20 minutes once the car is jacked up cause there's no obstructions to the parts really
Your diff is designed to have a certain amount of backlash, meaning the ring gear and the pinion move without contacting each other, idk how to best describe jt. Are your diffs ok? Maybe get a video while driving?
What would i notice of its the rear diff ? I only notice the click when there is a weight shift so like acceleration, reverse , putting it in drive and reverse
It's call the axle click. Most G and Z will have this during the lifetime of the vehicle. I had it too and got it fixed.
https://youtu.be/xXcfRnkjU_o
15jeffreyr
Sep 5, 2016 05:31 PM
