View Poll Results: What could it be
ECU
28.57%
Throttlebody
42.86%
Transmission
14.29%
idk
14.29%
Voters: 7. You may not vote on this poll
RPM Issue With G37
I have a 2008 G37s
Whenever i gas it and then when i take my foot off the gas the rpm drops to 500 and then goes back to what its supposed to be at
It happens in first gear,second gear and third gear.
Whenever it happens the car sounds like its about to die but never ever does die
No Mods to car accept a K&N filter but it does it before it had an stock air filter from dealer
Just wanted to see what it could be or see what it might be.
Its just been bugging me for a while and i was worried about it
Double check all of your intake connections and rubber hoses. Make sure they are tight, secure, and in good condition.
A 2008 with unknown mileage- have the throttle bodies ever been cleaned?
I think I know, Your torque converter is unlocked, and when you let off the revs have to catch themselves. Chances are it’s not catching early enough, I’d say try it in manual shift mode. Trust me, I hate this transmissions programming.
Make sure the trans is up to temp and give it a shot
Ye, i drove it in sport before and it still does it in like first and second at low speed thats where it sucks but it doesnt do often as it is in auto.
Also is there like a fix to this ? A tech said it might be a bulletin update which there is but he said that my car couldnt take the update cuz it was too old he said in terms of the date when the car came out
You need to clean the throttle bodies, then do the idle air relearn procedure
https://www.myg37.com/forums/engine-...learn-fix.html
If you still have the issue, start futzing with the trans
my personal experience is when the torque converter opens up, the revs drop anywhere down from 600 to 1000 for me. It’s very hit or miss, I don’t honestly know why. I’ve check vacuum leaks, TB’s, done relearns all myself and that just seams to be the way mine behaves.
