Coolant Leak
Old Jul 22, 2019 | 12:31 PM
OldG2NewG's Avatar
OldG2NewG
Coolant Leak
Ok so as of the last week I've been finding coolant stains on my driveway. So I decided to do some digging and thought it was my upper rad hose so I changed that. Then did a full coolant exchange and now it's leaking again but I think I know from where. I just want someone to confirm my logic.
So here's what I know and what I've did
The hose that routes to the ground from the reservoir is draining excess coolant from what I'm guessing. I may have put too much coolant in when I refilled the car.
Reservoir is bubbling as well (Temps have been 98+ the last week)
Changed rad cap with one from advance auto
So any ideas? Oil looks fine and I drove this car 5he week before on a 3 hr road trip and all was well.
Mod note: Title corrected to more accurately reflect thread content.
Old Jul 22, 2019 | 01:13 PM
Atowsley's Avatar
Atowsley
Being in Texas we have hot days like that almost everyday in summer. As long as I keep the coolant between the high/low marks no leaks. If I keep it at the high mark.. I get some overflow for what it's worth.
Old Jul 22, 2019 | 02:13 PM
Surfnazi's Avatar
Surfnazi
The overflow hose will leak out fluid if too much in system
Old Jul 22, 2019 | 02:52 PM
guy from norcal's Avatar
guy from norcal
Could be from passenger side by battery box. there is a plastic coupler that is prone to failing.
Old Jul 22, 2019 | 02:57 PM
OldG2NewG's Avatar
OldG2NewG
Ok I've been doing more digging and thinking, checked radiator after roll call and radiator looks bone dry, overflow is empty as well. I'm leaning towards a bad rad cap that isn't holding pressure as well. I just recently bought one from advanced auto and I'm assuming it could have been bad? Oem would be best in this case. Any other input is appreciated.
The coupler towards the passenger rear looks fine and I haven't noticed a leak under the car in that area. Only in the front right under the overflow
Old Jul 22, 2019 | 03:06 PM
Surfnazi's Avatar
Surfnazi
Dried rad fluid will cake up either at cap or hose
Old Jul 22, 2019 | 04:44 PM
OldG2NewG's Avatar
OldG2NewG
So from what I've gathered and read I'm either looking at a head gasket issues (which is weird but still a possibility) or a leak somewhere I'm not seeing. I will be doing a head gasket check tommorow to get that out of the way.
I'm hoping it isn't because I got the car less than 5 months ago and it was in pristine condition so I would hate to incur such a huge repair bill after owning the car for such a short amount of time.
I could swap the engine myself with a lower mileage one (I swapped engines in my last g35 in my driveway) but that's the last thing on my mind because of the sweltering heat these last few weeks.
I'll keep the post updated as I run tests.
Old Jul 28, 2019 | 05:00 PM
OldG2NewG's Avatar
OldG2NewG
New rad cap fixed the issue.
DigMy35x
Jul 5, 2010 08:13 PM
dainjarouz
Apr 26, 2010 01:28 PM
dezicartel
Nov 5, 2007 11:23 PM
