Help G37 throttle sensor not being recognized
Old Jul 24, 2019 | 02:52 PM
haleakalag's Avatar
haleakalag
Hi. 09 g37 at dealership now getting throttle bodies replaced (y, $2g+ proctology like experience w 25,000 miles). Anyway, they just called and have replaced all the parts, but cars not running right due to throttle sensors not being recognized. Said it’s some new reprogramming process they are trying to figure out. Anyone know anything about this? Thanks much.
Old Jul 24, 2019 | 03:34 PM
Surfnazi's Avatar
Surfnazi
They are plug and play assuming they put in right one
Old Jul 24, 2019 | 03:39 PM
haleakalag's Avatar
haleakalag
So no ECU reset or other computer program needed? Interesting. Hope they know what they're doing. It's at a Nissan dealership, not Infiniti.
Old Jul 25, 2019 | 01:55 PM
Surfnazi's Avatar
Surfnazi
Nope it's not like ecm that has to be coded to your car, and you sure it's the throttle body being bad and not the harness
Old Jul 25, 2019 | 02:16 PM
haleakalag's Avatar
haleakalag
Day 3 since install. Nissan just called and said that “one of the new throttle sensors was arcing. They were going to put in a new sensor. The service Dept said it was not uncommon. So, this is 2 new throttle bodies ($2600) with sensors included, and one is defective.” We’ll see what happens. I’m highly concerned.
Old Jul 25, 2019 | 03:11 PM
haleakalag's Avatar
haleakalag
Error Codes-
P2119 (before new throttle bodies)
P2135- after new throttle bodies, with alleged “arcing” of one sensor after replacement
Old Jul 25, 2019 | 03:52 PM
Surfnazi's Avatar
Surfnazi
Sounds like harness pin got damaged too
Old Jul 25, 2019 | 04:08 PM
haleakalag's Avatar
haleakalag
Thanks. I'll ask.
Old Jul 25, 2019 | 07:17 PM
jpowersjr2's Avatar
jpowersjr2
Jesus, might as well have gone with bigger throttle bodies (Rabbit Hole Motorsports, EPS) with that kind of money.
Old Jul 25, 2019 | 08:07 PM
haleakalag's Avatar
haleakalag
Y. Could almost put a down payment on a house, buy a new car back in 70s. It’s 3 days after the financial commitment/ install, I will be happy if it just cranks up and actually drives at this point. Standards really dropping. 25,000 miles on car, can’t wait til 50,000- prob be $10,000 for throttle bodies.
Old Jul 25, 2019 | 10:08 PM
saywat?'s Avatar
saywat?
tbs going bad is not a common occurance. did u touch them?
Old Jul 25, 2019 | 10:14 PM
haleakalag's Avatar
haleakalag
No, car wouldn’t start, got engine warning light. Went to Nissan dealership who installed new tbs 3 days ago. Not being recognized, then called yesterday and said one of the new ones has a bad sensor so trying another one. I hope to get it back before we are a gas-less society.
Old Jul 26, 2019 | 10:42 AM
Surfnazi's Avatar
Surfnazi
Car not starting wouldnt normally start with replacing tb. But since you paid them make sure they sort it out.
Old Jul 26, 2019 | 12:12 PM
haleakalag's Avatar
haleakalag
Well, we began w new battery, and the starter always worked. It would either start and drive perfectly, or crank up for a second or so and cut off. Finally, the service engine light came on, and got the error code p2119 8 days ago. Seems now they feel 100% that redoing the new defective throttle body will fix it. So it’s gotta be at least a 50% chance that will work. I called INFINITI parts and they said they’ve seen many bad throttle body sensors in replacement Parts. Besides the fact it’s taken 4 days (plus initial 3 day time waiting for parts there), I can’t understand why a car isn’t continually worked on until it’s fixed. This old in and out routine, replace bodies early Tues, then it’s still not working Tuesday PM (after calling me it will ready and my driving an hour to shop). Then getting a few daily failed to repair yet calls Wed and Thurs, and learning car was not being worked on continuously. Today is crunch day. We’ll see what happens.
Old Jul 26, 2019 | 04:22 PM
Surfnazi's Avatar
Surfnazi
Mist dealers dont stock them since it's expensive and not a part that goes bad normally
JakeG37
Apr 20, 2018 12:05 PM
adam
May 10, 2015 10:30 AM
Kuz
Oct 14, 2013 11:02 PM
dfw0837
General Tech Questions
Dec 7, 2011 08:31 AM
stryker2
Jun 1, 2009 09:20 AM
